5.0.1
Deploy via Azure Marketplace or Download Installer
How to install
Issues Addressed
- Blank browser after installing SquaredUp v5: Browser help displayed for unsupported Internet Explorer (SQ-3742)
Known Issues
- The Open Access Upgrade step does not run in the correct sequence of steps after upgrade, resulting in Open Access dashboards showing the error "Unexpected Request" and the Open Access Upgrade step being unexpectedly displayed when an administrator clicks an item on the navigation bar (SQ-3671)
- ServiceNow – No default view is used when API access is limited (SQ-2366)
The calculated totals for Treemap and Sunburst tiles do not include the cost of each item that, over the selected timeframe, does not exceed 0.50 in the currency unit for that item (SQ-2527)
5.0.0 (Release Candidate)
Download Installer
How to install
Improvements
- Major overhaul of the Dashboard Designer experience (SQ-1110)
- New Open Access (SQ-1216)
- Improved Web API visualisations and configuration (SQ-3062)
- Refreshed visual experience (SQ-3072)
- Internet Explorer no longer supported (SQ-3086)
See What's New in SquaredUp for Azure for more information.
Issues Addressed
- Miscellaneous Open Access bugs (SQ-1440, SQ-1473, SQ-2557, SQ-3148)
- Miscellaneous Dashboard Designer bugs (SQ-3254, SQ-1325)
- Matrix bar cell tile drops values on page refresh (SQ-3257)
Known Issues
4.8.1
Known Issues
- Deleted resources are not included when scoping the Cost Management tile leading to discrepancies with the Azure portal (SQ-1449)
- Where there are a large number of Open Access dashboards being shared, some may not load correctly (SQ-2557)
- The calculated totals for Treemap and Sunburst tiles do not include the cost of each item that, over the selected timeframe, does not exceed 0.50 in the currency unit for that item (SQ-2527)
4.8.0 (Release Candidate)
Improvements
- New SQL Line Graph tile (SQ-3073)
- New Scalar tile to show the latest performance data figure (SQ-2432)
- New scalable metric labels for Performance metrics (SQ-2384)
- Line colours can be matched across Performance graphs (SQ-2402)
- Option to use coloured Bar Top N graphs and match colours (SQ-2359)
Issues Addressed
- Cannot pin some Azure perspectives as a dashboard (SQ-3068)
Known Issues
4.7.1
Improvements
- Updated dashboard pack
Issues Addressed
Error occurs when drilling down from Summary Bar tile when the tile is on a perspective (SQ-3216)
Known Issues
- Deleted resources are not included when scoping the Cost Management tile leading to discrepancies with the Azure Portal (SQ-1449)
- Hidden types check box forces users to set scope when scoping is optional on some tiles (SQ-3144)
4.7.0 (Release Candidate)
Improvements
- New Cost Utilization Treemap tile
- Azure Monitor Logs enhancements
- New Resource Summary tiles
- Scoping by tenants with Azure Lighthouse
- Enhanced error handling
- "Show more" search results
Issues Addressed
- “JSON request was too large to be deserialized” error when drilling down on on a Performance graph (SQ-1360)
- Web Content tile does not allow left click of links (SQ-2917)
- Regex does not work in custom labels (SQ-2974)
Known Issues
4.6.0 (Release Candidate)
Improvements
- Cost Management enhancements; including Cost Overview Dashboard, Cost Drill Down and Top 5 resources (SQ-1198)
- Support for Azure Lighthouse (SQ-1199)
- Open Access theme setting (SQ-2534)
- Dashboard pack upgrades (SQ-1156)
- Enhanced installation experience (SQ-2483)
- Enhancements to restrict active content in HTML Tiles (SQ-1219)
Issues Addressed
- Open Access dashboards default to dark mode (SQ-1586)
- Deploying SquaredUp to a DS1 v2 VM can result in SquaredUp being unable to open see workaround (SQ-1560)
- High frequency of Cost Management API calls (SQ-2801)
- Cannot read property 'range' of undefined when drilling down on Alert Donut using page timeframe (SQ-2543)
Known Issues
- JSON request was too large to be deserialized error when drilling down on Performance graph (SQ-1360)
- Where there are a large number of Open Access Dashboards being shared, some may not load correctly (SQ-2557)
4.5.1
Issues Addressed
- Installations and upgrades fail if there are multiple bindings in IIS (SQ-2355)
- Pinned perspectives show as the last item in a folder regardless of where they are pinned (SQ-1585)
4.5.0 (Release Candidate)
Improvements
- Cost Management tile - New Line Graph, Tree Map and Sun Burst visualisations to help identify Azure costs
- Log Analytics visualisations - Line Graph and Donut visualisations for Logs data.
- Alerts donuts and drilldowns - Donuts and the ability to drilldown on Azure alerts.
- Performance tile enhancements - New heatmap visualisation for performance data.
- Export to Excel - the ability to export data to Excel for further analysis or sharing.
- Ability to publish perspectives via Open Access
- New Maintenance page for SquaredUp admins showing if a product update is available, remote administration tools, log levels and latest log files.
- A downloadable installer to allow on the box installs, not using the Azure Marketplace
- Alert tile improvements: view in the Azure portal, sort Alerts, rename columns, and option to show full date and time.
- Improved logging for the WebApi tile (SU-8065)
Issues Addressed
- The Alerts tile does not deep link to the Azure Portal (SU-7629)
- An error is shown in the Cost Management tile and no data is returned (SU-7948)
- A page exception occurs when drilling down into an Azure resource that has a space in the resource name (SU-7928)
- Performance Bar Charts do not show Custom Ranges with a negative value for the Min value as expected (SU-6689)
- Unable to link from the Web Content tile to a website that uses JavaScript (SU-7171)
- Non-permitted changes to sensitive queries are executed when admin views dashboard (SU-6730)
- Non-permitted changes to sensitive queries need an admin to revert changes (SU-8011)
- The ServiceNow tile can hit an overflow error when building large contexts (SU-8025)
- During deployment, the Networking panel waits indefinitely while generating a Public IP Address (SU-7894)
Known Issues
- Open Access dashboards default to dark mode (SU-8306)
- Deploying SquaredUp to a DS1 v2 VM can result in SquaredUp being unable to open see workaround (SU-8235)
- Duplicate deployment and uninstall tools after upgrading from SquaredUp for Azure v4.4 to v4.5 (SU-8136)
- Deleted resources are not included when scoping the Cost Management tile leading to discrepancies with the Azure Portal (SU-7709)
- Some Storage Accounts show unknown health state but are healthy when drilled into (SU-7848)
- No support for Metric Namespaces (SU-7491)
4.4.3
Issues Addressed
- HTTP Error 500 before activation when deploying in a personal Azure tenant (SU-8023)
Known Issues
- There are inconsistencies in the results returned by the Azure Cost Management API (SU-7896)
- No support for Metric Dimensions (SU-7492)
- Open Access dashboards default to Dark Theme and this cannot be personalised (SU-7963)
4.4.2 (Release Candidate)
Known Issues
