Overview
HTTPS is required to login to SquaredUp for Azure.
When deployed by the Marketplace SquaredUp can either be configured with a self-signed certificate with 12 months expiry, or a Let's Encrypt® certificate. It is best practice to replace a self-signed certificate with a trusted certificate prior to moving into production.
When deployed by the Marketplace SquaredUp will have configured a self-signed certification with 12 months expiry. It is best practice to replace this with a trusted certificate prior to moving into production.
When using the downloadable installer to install SquaredUp for Azure you will need to choose how you want to configure the SSL certificate. SquaredUp for Azure will only work using HTTPS.
At any point you can change your certificate options in IIS.
You have three options:
If you are trialling SquaredUp, and unsure which option to choose, you may choose to use a self-signed certificate for the duration of the trial.
If you are accessing SquaredUp via a public IP address it is best practice to purchase a trusted SSL certificate.
If you are accessing SquaredUp internally you can use an AD domain issued certificate.
Existing certificate
What this option does:
When to use this option:
Only choose this option if port 443 is not already being used for another app. If port 443 is already in use, or you wish to specify an IP address or different port number, then you should choose Configure later.
You should choose this option if you have already acquired and imported a trusted certificate. For example, if you are deploying SquaredUp on a web server that has already previously had a trusted certificate configured. This could be for a different application or for a previous SquaredUp installation.
What this does:
When to use this:
If you choose this option to use a self-signed SSL certificate then SquaredUp users will see a browser warning and will need to explicitly agree to proceed. In Chrome this is done by clicking Advanced.
If you are trialling SquaredUp, or unsure which option to choose, you may choose to use a self-signed certificate.
If you are accessing SquaredUp across the public internet it is best practice to use a trusted SSL certificate and not a self-signed certificate.
Configure later
What this does:
This will not configure any SSL bindings, you will need to configure an appropriate binding manually within IIS.
While you can choose to configure the SSL certificate later, please note that SquaredUp will not work until https has been configured with a SSL certificate.
When to use this:
You already have websites using port 443, or wish to use a different port number or IP address combination.
How to configure your own certificate
You will need to connect to your SquaredUp server.
- Log in using the credentials you specified when creating the VM.
- Launch IIS and under Connections select the server (squaredup).
- Double-click Server Certificates in the central panel:
- From the right-hand menu select Import and follow the steps to import your certificate.
- Under Connections expand Sites and select SquaredUpv5 or SquaredUpv4.
- From the right-hand side menu select Bindings.
- Select Add.
- Set the Type to https.
- Enter the new hostname/domain in the Host name field.
- Select the SSL certificate you added above under SSL certificate.
- Select OK:
- Select Close.
- From the right-hand menu select Restart.
FAQs
What are the downsides to using a self-signed cert?
If you choose the option to use a self-signed SSL certificate then SquaredUp users will typically see a browser security warning and will need to explicitly agree to proceed. For example, in Chrome this is done by clicking Advanced, in Edge by clicking Details.
What if I don't want to use a self-signed cert?
You need to acquire a trusted certificate either by purchasing one from a trusted certificate authority (CA), or one issued by your AD domain / internal certificate authority (CA).
What is a Let's Encrypt certificate?
