If you use a proxy server you may get an error when activating SquaredUp or configuring an OAuth Web API provider.
This provider has not been authorized (or there is an error with its configuration)
You need to configure SquaredUp to use the proxy, as described below. This will configure SquaredUp to use the proxy settings from Internet Explorer. For more information see the defaultProxy element article from Microsoft.
Adding a proxy to the web.config
You will need to connect to your SquaredUp server.
Edit the
web.config
file located in thesquaredupv4
folder.For an Azure Marketplace deployment the
squaredupv4
folder will typically be located atF:\squaredupv4
.For an install using the downloadable installer the default location is
C:\inetpub\wwwroot\SquaredUpv4
, but a custom location may have been chosen during the installation. -
Add the following XML snippet under the
<configuration>
section:<system.net> <defaultProxy enabled="true" useDefaultCredentials="true"> <proxy usesystemdefault="true" /> </defaultProxy> </system.net>
- If your proxy uses Active Directory for authentication, the responsible team will need to give your SquaredUp application pool user(s) access. For more information about identifying the SquaredUp application pool identity for each of your SquaredUp server see How to check and modify the application pool identity.
