Notifications are only visible to admins.
SquaredUp will periodically check for new notifications, which are visible from the top right-hand menu ☰ either via notifications or under system -> notifications. Notifications have different severity levels from informational, such as a new product release, to critical, like licence expiry.
Dismissing Notifications
