SquaredUp for Azure uses dark theme by default.
This can be changed by each user from the top right-hand menu ☰ > personalization by toggling the dark theme button to off to change to light theme.
Light theme for all Open Access dashboards
The theme for all Open Access dashboards is set from the right-hand menu ☰ system > Open Access.
Open Access dashboards in SquaredUp for Azure default to dark theme. This can be changed on the Open Access settings page to light theme by toggling the dark theme button to off.
This is a global setting which controls the theme for all Open Access dashboards, not just for the user who changes the setting. It is different to the individual user personalization theme setting described above.
