What is SquaredUp for SCOM?
SquaredUp for SCOM is a data visualisation platform for Microsoft System Center Operations Manager and OMS to create an advanced Enterprise Application Monitoring solution. Here are some key facts about SquaredUp:
- SquaredUp is a web application that takes the data in Microsoft System Center Operations Manager (and other sources) and presents it in fast, easy-to-use dashboards.
- You need Microsoft System Center Operations Manager (SCOM) in order to use SquaredUp.
- SquaredUp is deployed on a Windows Server in your environment (it's not a cloud-based app).
SquaredUp is so easy to install that it takes just 10 minutes to get up and running as you'll see in Installing for the first time.
You can download the latest version directly from here.
Take a look at the What's New article and Release Notes for more information on the updates and new features.
Using SquaredUp for the first time
Take a look at this introductory video 'Introducing SquaredUp for SCOM' (4 mins):
SquaredUp Resources
Take a look at YouTube for many video tutorials, from short walkthroughs, to in-depth training sessions:
Coffee Break Webinars
Bite-sized webinars, about 30 minutes long, focusing on specific SquaredUp features and scenarios. For example, ServiceNow Integration, Open Access under the hood, custom labelling.
Coffee Break Series - view recordings of past webinars.
Community Answers
Community Answers is a Q&A site for SCOM, OMS and SquaredUp related technologies.
Community Dashboards
Community Dashboards enables instant deployment of SquaredUp dashboards and perspectives (Dashboard Packs), based on expert contributions from the community.
SquaredUp Blog
To keep up to date with what's happening at SquaredUp don't forget to check out our blog!
SquaredUp Support
The documents on this support site cover everything you should need to know. If you have questions please contact SquaredUp Support.
