Feature | Free Trial | Essentials | Teams | Connect | EAM | Test | Enterprise* |
Standard features | yes | yes | yes | yes | yes | yes | yes |
Team Folders | yes | no | yes | yes | yes | yes | yes |
Open Access | yes | no | yes | yes | yes | no | yes |
High availability (HA) | no | no | yes | yes | yes | no | yes |
Web Content (iFrame) tile | yes | no | yes | yes | yes | yes | yes |
SCOM Task tile | yes | no | yes | yes | yes | yes | yes |
Personalisation (Dark Mode) | yes | no | yes | yes | yes | yes | yes |
SQL tile | yes | no | no | yes | yes | yes | yes |
Azure App Insights and Log Analytics tiles | yes | no | no | yes | yes | yes | yes |
ServiceNow tile | yes | no | no | yes | yes | yes | yes |
Web API tile | yes | no | no | yes | yes | yes | yes |
VADA | yes | no | no | no | yes | no | no |
EA Designer | yes | no | no | no | yes | no | no |
PowerShell-based availability monitoring | yes | no | no | no | yes | no | no |
TCP link dependency monitoring | yes | no | no | no | yes | no | no |
End user availability reporting | yes | no | no | no | yes | no | no |
Named Users | unlimited | 3+ | 10+ | 10+ | 10+ | 3 | 10+ |
Test licence | no | no | yes | yes | yes | yes |
All editions include the standard tiles: Status, Monitors, Alerts, Matrix, Image, SLA, and Performance.
For more information about licence pricing see pricing information.
* Enterprise edition is no longer available to purchase.
Where to find your v4 activation key
You will need a v4 licence activation key to install SquaredUp v4. You will have received this by email following your purchase or free trial. If you already have SquaredUp v3 please see How to migrate from SquaredUp v3 to v4 for information about getting a v4 activation key and further considerations.
Licence information
The Trial licence allows for unlimited users and all features for a 30 day evaluation in your own environment and is available from here
The Primary licence should be used on your first SquaredUp Production server.
The Secondary licence is only for use in high availability (HA) configurations. See How to configure high availability
The Test licence designed for your test or dev lab is included free of charge with the Teams, Connect and EAM editions. If you need any extra features please contact Sales.
Feature information
The Visio tile enables you to transform Microsoft Visio diagrams into live HTML5 dashboards showing real time SCOM health state. See How to use the Visio tile.
The Web Content (iFrame) tile enables you to enrich your dashboards with data from other web pages and custom HTML. See How to use the Web Content tile
The SQL tile enables you to display data from any external SQL database in your dashboards. See How to use the SQL tile
The SCOM task tile allows you to display up to date in-depth data in SquaredUp without adding the data to your Data Warehouse. See How to use the SCOM Task tile.
The Azure tile allows you to add Azure App Insights and Log Analytics queries in your dashboards and perspectives.
The Web API tile allows you to use Web API (i.e. RESTful) queries in your dashboards and perspectives to automatically display contextual data from other web data sources, such as Google APIs or Splunk. See How to use the Web API tile. There are also dedicated tiles for ServiceNow, Azure Application Insights and Azure Log Analytics.
Team Folders enable you to deliver dashboards and delegate control to different teams within your organisation (or to different clients if you are a service provider). See Team Folders.
Personalisation allows individual users to choose to use SquaredUp in either light theme or dark theme.
Open Access enables easy sharing of dashboards throughout your organization. Open Access allows users to view a version of the dashboard with simplified interactivity. Open Access dashboards do not require authentication and do not consume Named User licences. See Open Access.
High availability (HA) allows you to set-up SquaredUp in a load balanced configuration using your Primary licence and Secondary licence. See How to configure high availability
VADA is Visual Application Discovery & Analysis see What is VADA?
EA Designer enables you to create Enterprise Applications see What are Enterprise Applications? and How to create Enterprise Applications.
PowerShell-based availability monitoring allows you to use a PowerShell script to test application availability. Take a look at the webinar Advanced Application Availability Monitoring (40 mins).
End user availability reporting - The Report Availability option for Enterprise Applications (EA) allows you to manually change the health state of an application from available to either degraded or unavailable, as well as enter your own message to users. See How to manually set the health state of an application.
Named Users refers to the number of users who can log on to SquaredUp, and is restricted by the number of licences (Named Users) you have purchased. See How to manage Named Users
The Support Portal allows access to online and email support from SquaredUp https://support.squaredup.com/
