By default, all servers share the same configuration files when configured for high availability (HA). This means that they connect to the same SCOM server, use the same Open Access loopback URL (v4), use the same Data Warehouse etc.
If a server needs to use a different or unique configuration to the other servers then there are two things to consider:
- When using multiple SCOM servers or SQL servers we recommend that these are load balanced, for example using a SQL Listener or load balanced SCOM.
- If these services cannot be load balanced then 'configuration redirections', as described below, can be set up to give each server its own unique copy of a configuration which is not shared over HA.
Configuring different SCOM servers
You may wish to configure each SquaredUp server to use a different SCOM server, as an alternative way of ensuring SquaredUp remains up if one of the SCOM servers goes down. You can do this by defining separate SCOM connectivity settings for each server, for example, one SquaredUp server pointing at SCOM server 1 and the other at SCOM server 2. To do this, follow the steps below, running the haconfigs
command on the HA server that you want to target at a different SCOM server and using the file name scom.json
Configuring different Open Access loopback URLs
On SquaredUp v4 you can also configure different SquaredUp servers to use different Open Access loopback addresses. To do this set the loopback as normal for the Primary server and then follow the steps below running the haconfigs
command on the Secondary server and using the file name openaccess.json
to set a different loopback URL for the Secondary server. The loopback URL is only necessary on SquaredUp v4.
Connecting to different Data Warehouse database instances
If you wish to configure SquaredUp servers to use different Data Warehouse database instances follow the steps below, running the haconfigs
command with the file name connections.json
. This will only work if the database instances are for the same Data Warehouse and the same Management Group.
Configuration redirections
- On the server that you wish to have a different configuration, such as your Secondary SquaredUp server, open a command prompt as an administrator (from Start > Run type
command prompt
, rightclick on the Command Prompt icon and click Run as administrator). -
Change to the SquaredUp installation location, which by default is
but may have been changed at installation, for example type:cd C:\inetpub\wwwroot\SquaredUpv5
orcd C:\inetpub\wwwroot\SquaredUpv4
Run the squaredup4 or squaredup5 command depending on your version:
squaredup5 haconfigs --filename=<filename>
orsquaredup4 haconfigs --filename=<filename>
command to create a unique local-only configuration, where<filename>
is the configuration file you wish to make unique for this server.For example:
squaredup5 haconfigs --filename=scom.json
to create a unique SCOM server address configuration for this serversquaredup5 haconfigs --filename=connections.json
to point this server to a different Data Warehousesquaredup5 haconfigs --filename=openaccess.json
to add a unique Open Access loopback URL
After running the command, you will automatically be presented with an elevated Notepad, allowing the file to be edited for use on the local server only:
- Edit the file as required, and save your changes.
- For some configurations to come into effect, you will need to recycle the SquaredUp application pool. This tool does not automatically recycle the application pool after making or editing a configuration. You can recycle the SquaredUp application pool from IIS or by running the command
squaredup5 recycle
orsquaredup4 recycle
Viewing redirects
You can view which configurations are unique to the current server by running squaredup5 haconfigs
or squaredup4 recycle
with no additional arguments. This will also show how the local file is different to the HA-shared copy:
Editing an existing redirect
If you run squaredup5 haconfigs --filename=<filename>
or squaredup4 haconfigs --filename=<filename>
where there is already a redirect in place for <filename>
, an elevated notepad will be opened to allow you to edit the local configuration file.
Removing redirects
To remove a redirect, run:squaredup5 haconfigs --filename=<filename> --delete
or
squaredup4 haconfigs --filename=<filename> --delete
A manual confirmation is required to finish deletion.
