The dashboard designer allows you to configure and edit the layout of the tiles on the page. The dashboard designer works in the same way whether you are designing a dashboard or a perspective, but before you start you may find it helpful to understand which is best suited to your needs: How to create a dashboard and How to create a perspective.
The dashboard designer has been significantly improved in version 5, and we recommend that everyone upgrade to the latest version. In v5 it is possible to create tile layouts that were only possible by editing the page JSON in older SquaredUp versions see How to use the dashboard designer (v5).
The dashboard is saved as you go along so there's no need to save your changes. You can find your draft dashboard by clicking on the right-hand menu ☰ > system > unpublished. Your draft dashboard is not visible to anyone other than you until you publish it.
You can toggle between edit mode and view mode by clicking the edit this dashboard button at the top right:
This article covers:
You may also like to watch this short 5 minute video about using the dashboard designer, which is part of our Fundamentals Quick Win video series:
Dashboard layout
When you create a new dashboard a new tile configuration is opened automatically for you:
Click on the tile you want to configure. For more information about how to configure each tile type see the relevant article in this KB folder:
Squaredup for SCOM > Dashboarding > Tiles
Add new tile
To add a new tile click the add new tile button:
Add column
To add a column move the move to the right-hand side of the page until the column button appears and then hover over it and click on the + plus that appears.
Resize columns
Hovering anywhere between columns shows the resizing arrow. You can drag the column to any width or snap to the 25%, 33%, 50%, 66% or 75% lines.
Delete a column
To delete a column hover above the column and the layout helper will change to a bin, which you can click to remove the column.
Move tiles
Tiles can be dragged and dropped anywhere on the dashboard. Click on the white area at the top of the tile and hold the left mouse button down while you drag the tile around the dashboard.
Grey areas indicate where the tile can be dropped:
Tile buttons
Delete tile
Clone tile
Edit tile
The cog or edit tile button takes you into the configuration settings for the tile.
For more information about how to configure each tile type please see the relevant article in this KB folder:
Publishing your dashboard
The dashboard is saved as you go along so there's no need to save your changes. You can find your dashboard by clicking on the right-hand menu ☰ > system > unpublished.
Clicking publish will make the dashboard visible to others on the menu where you created it. Discard will delete your draft dashboard.
Find out how to publish dashboards to a subset of users using Team Folders, or visible to anyone even unlicensed users with Open Access.
FAQs
How can I control the size of Visio diagrams?
SquaredUp will resize a diagram in the Visio tile to fill the column width. Resizing the column will make the diagram increase or decrease in size accordingly. You can also affect the size a Visio diagram is displayed in SquaredUp by adding or removing the white space around the diagram in Visio as described below and in this article https://support.microsoft.com/en-us/kb/285024.
If you would like your Visio diagram to appear smaller within the column: In Visio increase the size of the white space (padding) or page around the diagram by holding down CTRL and dragging the corner of the page. Then save the SVG, and drag the new SVG file into the SquaredUp Visio section again.
See The Visio diagram is too large when displayed in SquaredUp
If you would like your Visio diagram to appear larger within the column: In Visio reduce the size of the white space around the diagram, save the SVG and drag the new SVG file into the Visio section again.
See The Visio diagram is too small or has too much white space around it
