The SLA tile displays gauges showing the availability of SCOM objects, such as servers or applications, based on your SCOM Monitor Service Level Objectives (SLOs).
Before the SLA tile can be used, you must have one or more Monitor SLOs defined in your SCOM management group. The slo selection drop down only lists the Monitor SLOs from SCOM.
SquaredUp does not support Collection Rule SLOs, or the unmonitored state, which should not be ticked.
Creating an availability Service Level Objective for your distributed applications
The following steps describe how to create a Monitor Service Level Objective (SLO) that can be used for all of your Distributed Applications. If you already have Monitor SLOs configured in SCOM, you can use those.
- Open the SCOM Operations Console.
- Go to Authoring workspace (Authoring tab on bottom left).
- Select Authoring > Management Pack Objects > Service Level Tracking in the left-hand tree view.
- Click Create in the right-hand task pane.
On the General page, enter the following details and click Next:
Name: Service Availability
Description:
<leave blank>
- On the Objects to Track page click Select... next to Targeted class
- Set the Search result filter dropdown to Distributed Application
- In the list, select Service (from System Library). Click OK
- Ensure the Scope is set to All objects of the targeted class
- Click the New button to create a new management pack, for example
SlaTest
On the Service Level Objectives page click Add > Monitor state SLO.
SquaredUp does not support Collection Rule service level objectives.
Enter the following details and click OK
Service level objective name: Availability
Targeted class: Service
Monitor: Availability
Service level objective goal: 99.000
Specify states: Critical is checked
SquaredUp does not support unmonitored, and it should not be ticked.
- Click Next. On the Summary page, click Finish
