This article covers how to create and modify row perspectives. These are used by the Matrix tile, VADA analyse mode and Status Donut drill down pages to display KPIs, properties, SLA and health information for the object being viewed.
Row perspectives work in a similar way to dashboard perspectives in that they are stored in dashboard packs, they use a match criteria that defines which class, group or particular object they apply to, and they have a rank that specifies which row perspective should be displayed when multiple row perspectives match.
You may like to watch the SquaredUp webinar - Matrix Tile Deep Dive.
We recommend you don't edit the SquaredUp row perspectives. A good way to start is by copying the JSON from an existing row perspective and amending as you require.
Where row perspectives are used
Row perspectives in the Matrix tile
Walkthrough: Creating a row perspective
A row perspective defines the data to be shown, as seen here on the Matrix tile:
And here on VADA analyse view:
When configuring the Matrix tile you can choose which row perspectives to use in the columns section. When dynamic is selected you can either leave the setting as auto which will automatically use the row perspective with the highest rank, or you can click on the row perspective you want to use. The walkthrough below describes how to add a new row perspective to appear on this list.
New row perspectives can be created on the SquaredUp server by creating a new a row perspective JSON file. A good way to start is by copying the JSON from an existing perspective and amending as you require.
- Log on to the SquaredUp server and run Notepad as an administrator.
- Create a JSON file in the directory:
C:\inetpub\wwwroot\SquaredUpv4\User\Packages\Everyone\perspectives\rows - Below is the json configuration template for a row perspective. You can copy this into the JSON file you have created.
{ "_comment": "My new row perspective", "format": "row", "id": "NEWGUID", "match": { "groupIds": "SCOMID", "type": "scom/object" }, "name": "My new row perspective", "rank": 40, "columns": [ { "_type": "celltile/status", "title": "State" }, { "_type": "celltile/text",
"title": "IP Address" "config": { "display": { "contentTemplate": "{{(properties.ipAddress || '').split(',')[0]}}" } }, }, { "_type": "celltile/signalstrength",
"title": "#CPUs" "config": { "display": { "valueProperty": "properties.logicalProcessors" } }, }, { "_type": "celltile/scomperf-as-sparkline",
"title": "CPU", "config": { "display": { "height": 30, "width": 120 }, "source": { "objectname": "Processor Information", "countername": "% Processor Time" } } }, { "_type": "celltile/bar",
"title": "Logical Disk Free Space", "config": { "source": { "objectname": "LogicalDisk", "countername": "% Free Space" } } } ] } - Each row perspective JSON file must use a unique "id". Create a new GUID ready to use for the row perspective. You can do this simply by typing
new-guid
into PowerShell. - Replace NEWGUID with the new GUID you have created.
- Find the SCOM ID of the group or class you want this row perspective to be displayed for. See How to find the SCOM ID of an object or group.
- Replace SCOMID with the SCOM ID of the group or class you want this row perspective to be displayed for.
For example, for the IIS Computer Group:
"match": { "groupIds": "603c9394-cbf5-a5d1-be77-45c0d6755902", "type": "scom/object" },
- Save your new JSON file.
- In SquaredUp click on the top right-hand menu ☰ > system > dashboards then click the reload button at the bottom of the page.
- Create or edit a Matrix tile scoped to the group or class specified in your row perspective. See How to use the Matrix tile
- In the columns section your new row perspective should be available for you to select. It is the name you put in the _comment that is displayed here.
- You can now edit the row perspective JSON file and re-save as required. See the Reference section at the end of this article and the Matrix tile article for more information about the cell tile options available.
FAQs
How can I edit the drill down page for a Status Donut?
How can I edit the row perspective shown in VADA analyse mode?
The row perspective shown in VADA analyse mode is the highest ranked row perspective defined for the object.
Can I edit the existing row perspectives?
We recommend you don't edit the SquaredUp perspectives. Instead copy an existing row perspective JSON file and edit as you require. Don't forget to replace the "id" with a new GUID. You can create a new GUID simply by typing new-guid
into PowerShell.
Reference
_comment: Provide a unique name which will be seen in the list of row perspectives to choose from when configuring a Matrix tile.
id: Provide a GUID that should be unique to this row perspective. You can generate a new GUID by typing new-guid
into PowerShell or online here. You should create a new GUID for each row perspective. Altering the existing GUID randomly will not work.
format: row (This property differentiates a row perspective from a regular perspective)
type: scom/object
classIds: ID of the class of objects on which the perspective should apply to. You need to replace this with the ID relevant to you. See How to find the SCOM ID of an object or group.
groupIds: ID of the group of objects on which the perspective should apply to. You need to replace this with the ID relevant to you. See How to find the SCOM ID of an object or group.
name: Unique name for the row perspective
rank: Rank specifies which perspective should be displayed when more than one perspective matches the scoped criteria. 0 is the lowest rank and will be considered the lowest priority. Best practice is to assign numbers with sufficient gap between them (like multiples of 10) so that you can later insert other perspectives of lower ranks in between if you wish to.
columns: Column is an array of cell tile definitions. You need to define cell tiles in the column block. Please refer Reference: Cell tile definitions to define custom cell tiles as per your requirement.
For more information see How to use the Matrix tile
