This article describes the one-time configuration to create a Pingdom provider for use with the Web API tile. For more information on how to use the tile see How to use the Web API tile with Pingdom
These steps guide you through how to create a simple provider:
- Log on to SquaredUp and navigate to the right-hand menu ☰ then system and then click on the web api perspective.
- Click Add new provider.
Leave the provider type as simple
- In the service name box type in a suitable name, e.g. Pingdom
We recommend you include the API version here in the base URL, so if the API version changes you only need to update it here, rather than in every tile. - Under default headers click add
Add the following:
value:Bearer
<API token from Pingdom>
You can create an API token by logging in to Pingdom > Integrations > The Pingdom API > Add API token
Paste the API token into the authorization value box in SquaredUp, prepended by the wordBearer
- Click add provider.
