CVE: CVE-2020-9389
Username enumeration is the ability to find out valid usernames with an automated process, for example based on the server's response to a username. Before SquaredUp version 4.6, it was possible to determine valid usernames based on the different amount of time it took the server to respond to valid and invalid usernames.
Fix
The server's response time for valid and invalid usernames is constant.
What should you do?
If you are using a SquaredUp version earlier than 4.6, update to version 4.6 or later.
SquaredUp for SCOM | Versions earlier than 4.6 | 4.6 and later versions |
Acknowledgement
SquaredUp would like to thank Giuseppe-Diego Gianni from NATO for reporting this vulnerability.
Please contact our support team if you have any questions about this vulnerability or need further help: support@squaredup.com
3.2.2021 | Initial release |
