CVE: CVE-2020-9390
Before SquaredUp version 4.6, stored XSS was possible for Web Content and Visio tiles. Exploiting this vulnerability was possible for SquaredUp users who can create dashboards.
Users could create a dashboard with a Web Content tile that embeds an iframe pointing to malicious JavaScript. For example, it was possible to point to a page that emulates session timeout and asks for credentials when a user views the dashboard.
Users could also create a dashboard with a Visio tile that uses an SVG with malicious script to execute in a user's session.
Whenever a user would view a dashboard with the malicious content, the JavaScript would be executed in the context of their browser.
Fix
JavaScript is now blocked from iframes in Web Content tiles. A purifier for SVG images has been implemented to ensure the image is free from malicious scripts.
What should you do?
If you are using a SquaredUp version earlier than 4.6, update to version 4.6 or later.
SquaredUp for SCOM | Versions earlier than 4.6 | 4.6 and later versions |
SquaredUp for Azure | Versions earlier than 4.6 | 4.6 and later versions |
Acknowledgement
SquaredUp would like to thank Giuseppe-Diego Gianni from NATO for reporting this vulnerability.
Please contact our support team if you have any questions about this vulnerability or need further help: support@squaredup.com
3.2.2021 | Initial release |
