When SquaredUp have modified your license, for example you have renewed, upgraded your license or purchased more named users, you will need to reactivate the license for the changes to take effect. These instructions apply if you have been told to use the same license activation key as before.
If you have been sent a new license activation key, if for example your license expired before you were able to renew, you should enter the new key on the activation screen (see How to activate your license) when prompted when you open Dashboard Server.
Use this article if you have been asked to reactivate an existing license activation key.
Reactivating your license
- Log in to Dashboard Server as an admin user (How to make a user a Dashboard Server administrator). If you have more than one SquaredUp server and both licenses have been updated, then you will need to log on to each server to reactivate the Primary and Secondary licenses in turn.
- Browse to the right-hand menu ☰ > system > licensing.
In the Active License section at the top of the page click on the reactivate button.
- Click confirm.
Following activation
Browse to your Dashboard Server instance.
If you used the downloadable installer to install Dashboard Server:
By default, the URL to your Dashboard Server instance is: http://SquaredUpServer/SquaredUpInstance
SquaredUpServer
is the name of the server where Dashboard Server is installed.
By default, SquaredUpInstance
for version 5 is SquaredUpv5
and for version 4 is SquaredUpv4
. If you gave your Dashboard Server instance a different name when you installed it, use the name you chose for your instance.
If you deployed Dashboard Server from the Azure Marketplace:
The URL is https://DNSName
of the virtual machine (VM) deployed.
