CVE-2021-40096 - Stored cross-site scripting (provider configuration)
CVE:CVE-2021-40096
Before Dashboard Server version 5.3.1, stored XSS was possible when creating an Azure Active Directory, Azure App Insights, or Azure Log Analytics provider. This vulnerability allows remote attackers to inject arbitrary web script or HTML.
What should you do?
Acknowledgement
