Enterprise Applications - How to configure an availability test
An availability test is used to determine the health of an Enterprise Application (EA).
- Availability test
- Map (see Enterprise Applications - How to map an Enterprise Application using VADA)
- Dependencies (see Enterprise Applications - Dependencies)
This article describes how to configure an availability test. You can also How to manually set the health state of an application.
Only the availability monitors configured here roll up to be displayed as the health of the EA. These monitors test whether the application is actually available to the end user.
When creating a new EA or editing an existing EA click the configure availability monitoring button.
Change the enable monitoring toggle button from off to on.
Select the type of availability monitoring you wish to configure:
Simple URL monitoring - create a simple URL monitor
Simple TCP monitoring - create a simple TCP monitor
Custom PowerShell - use a PowerShell script to test application availability (see the Webinar Advanced Application Availability Monitoring)
Existing monitoring - allows you to add any availability monitor or object that you already have in SCOM, for example Web application availability monitoring or Web application transaction monitoring.
Complete the details required.
Select a group of test clients (Watchers) from the test from drop down box (this is not required for existing monitoring because this will already have been configured in SCOM). This is where you want the tests to be run from, and should be physically close to the end users who will be using the application. This is simply a SCOM group where the name starts with
EAM_, see How to create Availability Test Groups for use with Enterprise Applications.
The outcome of the chosen availability test will roll up to the overall health of the Enterprise Application. If you consider editing the rollup seeHow to edit Enterprise Application rollups.
