How to add a Pingdom provider
Before you configure the Web API tile for use with Pingdom you need to create a Pingdom provider in Dashboard Server.
You may like to refer to the Pingdom API documentation or speak to your Pingdom expert.
For Pingdom the provider must be created as a simple provider:
Add the following:
value:Bearer<API token from Pingdom>You can create an API key (token) by logging in to Pingdom > Settings > Pingdom API > Add API token
Bearerand a space
Click Save.
