How to create a dashboard
This article covers:
- View mode buttons
For detailed information about dashboard layout, adding columns, rows, and split tiles see How to use the dashboard designer.
If you're looking for some real-life examples of Dashboard Server dashboards, check out our GitHub Samples repository. You'll find dashboards built by the community as JSON exports you can use as templates for configuring your own dashboards.
Dashboard Server Community Edition > Dashboarding > Tiles
Creating a new dashboard
In Dashboard Server navigate to where you'd like the dashboard to be created. Hover over the + button and click dashboard.
Edit tile - Configure tile
The most important part of any dashboard is the data. The edit tile (cog) button and configure tile links both allow you to choose the kind of tile you want to add and then configure it.
Publishing your dashboard
Who can view the dashboard?
On the main menu your dashboard will be visible to everyone.
If it is within a Team Folder
If the dashboard has Open Access enabled, or is added to the Open Access navigation bar, then it will be visible to anyone, even unlicensed users
Edit mode buttons
Discard a draft
If a dashboard is not published yet (draft), the discard and discard changes buttons will delete it.
If the dashboard has been published, and then you make changes, discard will discard the changes and leave the previously published dashboard live.
If you unpublish a dashboard and then discard changes then the dashboard will be deleted.
Unpublish
Once your dashboard is published you will see an unpublish option if you click on the cog to edit the dashboard.
Unpublishing the dashboard removes it from view. You are asked to confirm this, as the dashboard will return to only you being able to view it.
If you discard a dashboard after unpublishing it then the dashboard will be deleted.
Move
This allows you to move the dashboard to a new location on the navigation bar.
Delete a published dashboard
The easiest way to delete a dashboard is to navigate to it, click the edit
button and then click the delete button.
Other options to delete a dashboard are:
You can delete the dashboard from the navigation bar. Deleting it from the navigation bar will delete it completely, not just from the navigation bar.
Information about editing the navigation barThe global navigation editor is accessible only by
Dashboard Server administrators () from the right-hand menu ☰ > edit navigation or system > dashboards.This allows
Dashboard Server administrators to reposition globally viewable folders and Team Folders on the navigation bar, as well as the ability to move any globally viewable dashboards.
The edit team folder icon is shown next to Team Folders and clicking it will take you to the Team Folder settings page where you can view and sort the dashboards within the Team Folder.
The delete button will delete items. This deletes the dashboard or folder and sub-contents completely, not just from the navigation bar. If the dashboard is in a folder, you can go to the folder settings
, click the edit
Clone
This creates a copy of the dashboard in the same location, ready for you to edit.
Edit actions
This allows you to add a button at the top of a dashboard.
For more information see Action buttons for dashboards.
Edit JSON
This allows you to see and edit the JSON behind the dashboard, which can be useful for troubleshooting with the help of SquaredUp Support
Click on the
edit dashboard buttonClick on the
edit JSON button.You see the dashboard's JSON.
Settings
Dashboard settings apply to the whole dashboard.
Graph colors are set to match by label by default, meaning that the same color will apply to an object with the same label across several graphs. See How to enable graph color matching.
View mode buttons
When you are not in Edit mode you will see the following buttons at the top-right of the dashboard:
Page timeframe
If you're looking for general information about what kind of timeframes can affect a tile please read Timeframes for tiles.
The page timeframe is the timeframe setting a dashboard is currently using. When a user changes the page timeframe, all tiles that use the page timeframe will adapt to the new timeframe. Tiles that don't use the dynamic page timeframe aren't affected and won't change.
Default page timeframe
Within Dashboard Server, it decides which timeframe a dashboard uses when a user goes to the dashboard. Tiles that use the page timeframe according to their settings (not a fixed, specific timeframe) will use the default page timeframe every time the dashboard or perspective is opened. Users can change the page timeframe temporarily while they are on the dashboard, but their setting will only last until they leave the page. Their setting will only affect their view of the dashboard, not other users' views.
On Open Access dashboards, tiles that use the page timeframe according to their settings always use the default page timeframe.
Since Dashboard Server 5.3 you can change the default page timeframe for dashboards. Changing the default page timeframe of a dashboard will affect this individual dashboard and it's Open Access representation.
Note: The system-wide default page timeframe is "last 12 hours" for any Dashboard Server installation, but you can change this setting since Dashboard Server 5.3. This will affect all dashboards (including Open Access dashboards) that don't have an individual default page timeframe setting.
Note: If you are sharing the dashboard via Open Access, these changes will also affect the Open Access dashboard.
Go to the dashboard you want to change the individual default page timeframe for.
On the dashboard, click the edit button
Click the settings button.
Choose the new default timeframe under Default timeframe.
The dashboard will now by default use the page timeframe you chose. Users can still temporary change the page timeframe while looking at the dashboard.
Tip: If you want to undo the individual page timeframe setting to let the dashboard use the system-wide default timeframe again, you need to switch to the JSON view of the dashboard and delete the parameter that defines the dashboard's page
timeframe(for example "timeframe": "last7days").
Note: This setting affects all dashboards (including Open Access dashboards).
notepad, and then right-click and select Run as administrator).In your Dashboard Server folder, go to
\User\Configurationand find theextensionpacks.jsonfile.
For example, for Dashboard Server v5 the default folder location isC:\inetpub\wwwroot\SquaredUpv5Open the
extensionpacks.jsonfile and add the propertydefault-timeframewith the value for your new default page timeframe for all your dashboards and perspectives.Example for a default timeframe of 24 hours:
Copy{
}Possible values for the
default-timeframeproperty:last1hour,last12hours,last24hours,last7days,last30days,last3months,last6months,last12monthsSave the json file.
Export dashboard to Excel
Dashboard Server allows you to export the data shown on a dashboard to an Excel spreadsheet, using the Export to Excel button shown at the top right of the screen:
Each tile is exported to a separate tab within the file which is saved to the user's downloads folder.
Share this dashboard
