How to use the Web API tile with ServiceNow
This article covers how to use the Web API tile to query data from ServiceNow and display this data in Dashboard Server.
The ServiceNow tile offers easier configuration than the Web API tile. You can display incidents and change request with the ServiceNow tile. If you want to use any other data from ServiceNow, you need to use the Web API tile.
You can also watch the Webinar: Web API and ServiceNow
For more information about using the dedicated ServiceNow tile see How to use the ServiceNow tile.
This article covers these areas:
- Prerequisites
- Configuration in ServiceNow
- Adding ServiceNow as a Web API provider in Dashboard Server
- Walkthrough: Configuring the Web API tile for ServiceNow
Prerequisites
- If you use a proxy server you may need to configure the proxy
(How to configure Dashboard Server to use a proxy) . - A ServiceNow account. It depends on the roles of the ServiceNow account you use for the ServiceNow provider what functions are available in the ServiceNow tile.
The permissions of the ServiceNow account you are using for your ServiceNow
We recommend using a service account, which means you create an account specifically to use with the ServiceNow
ServiceNow admin account
provider s.
sys_filter
sys_dictionary.*
sys_dictionary
sys_db_object
sys_ui_list
sys_db_object.*
sys_ui_list.*
The tile can be scoped
| ServiceNow admin account | ServiceNow non-admin account with ACLs | ServiceNow non-admin account without ACLs | |
| Being able to scope the tile | yes | yes (due to the ACLs) | yes (due to the web_service_admin role) |
| Being able to see all views in the View dropdown, not only the default view | yes | no | no |
| Being able to see all default filters, not only user-made ones | yes | yes (due to the ACLs) | no |
- In your ServiceNow account in the Application Navigator (left-hand menu) go to System OAuth and click Application Registry.
Dashboard Serverand leave the other default settings as they are. - Once you've created the endpoint, open the entry to view the client ID and client secret. Click the padlock next to the client secret to see it.
- Log on to Dashboard Server and navigate to the right-hand menu ☰ > system > Integrations
- Under Integrations click on Web API, and then OAuth and type in a suitable name, e.g. ServiceNow.
- Change the grant type to password.
- The base URL should look something like
https://instancename.service-now.com/api/now/whereinstancenameis your instance. If ServiceNow is installed on-premises, this may be something different. This URL is prepended to every request URL. - The token URL will be something like
https://instancename.service-now.com/oauth_token.dowhereinstancenameis your instance. - username and password are exactly those used to sign into the account which was setup with the permissions mentioned in the prerequisites.
- client id and secret are taken from the notes you made earlier.
- Leave the authorization scope empty
- Click save.
If the provider is not authorized it could be that some of the provider configuration is incorrect (for example the username, password, secret etc), or if you use a proxy it could be that the proxy is not configured
This walkthrough takes you through configuring a simple tile to show a list of the open incidents.
Take a look at the ServiceNow documentation on the ServiceNow Aggregate API
You can also watch the How to integrate SquaredUp and ServiceNow tutorial Video.
Create a new dashboard and click on the Web API tile.
Select Web API (Grid).
The scope section allows you to specify resources, which can be used later in the tile configuration to insert resource properties into the query. For this walkthrough you can leave the scope empty.
In the provider section select the ServiceNow provider that you created.
In the http mode section paste
table/incidentinto the URL box to make this a GET request totable/incident. This base URL is prepended to the URL.In the headers & data section click add under data to add the following parameters to the request to select the correct data and format for the grid:
name:
sysparm_display_valuevalue:true. This will show the display value of any columns which are IDs by default.name:
sysparm_fieldsvalue:sys_id,urgency,short_description,severity,state,assigned_to. This will only select the fields we are interested in. You can compile a list of fields using the REST API Explorer on your own ServiceNow instance.name:
sysparm_limitvalue:20. This will limit the number of results to the first twenty.name:
sysparm_queryvalue:active=true. This will show open tickets only.
In the response data section, paste
resultinto the box.Rows of data should now be shown.
The grid columns and grid options sections allow you to configure the columns and column names.
In the grid columns section, hide the
sys_idcolumn, rename and reorder other columns as you like. Some columns, likeassigned_towill be returned as[object Object]. Click edit next to these columns, and then click the {} icon, then select the display value to have these display correctly.In the grid options section, we can set the row link to make each row hyperlink to that ServiceNow incident. To make each row replace the
sys_idwith the one from that object the URL should behttps://<your-instance>.service-now.com/nav_to.do?uri=%2Fincident.do%3Fsys_id%3D{{sys_id}}For more help customizing the columns of data see How to use the Grid Designer.
Click done.
