CVE-2020-9389 - Username enumeration possible via a timing attack
CVE: CVE-2020-9389
Username enumeration is the ability to find out valid usernames with an automated process, for example based on the server's response to a username. Before Dashboard Server version 4.6, it was possible to determine valid usernames based on the different amount of time it took the server to respond to valid and invalid usernames.
Fix
The server's response time for valid and invalid usernames is constant.
What should you do?
If you are using a Dashboard Server version earlier than 4.6, update to version 4.6 or later.
| Product | Affected versions | Resolved versions |
| SCOM Edition | Versions earlier than 4.6 | 4.6 and later versions |
Acknowledgement
SquaredUp would like to thank Giuseppe-Diego Gianni from NATO for reporting this vulnerability.
| 3.2.2021 | Initial release |
| 10.6.2021 | Updated support contact information |
