Dashboard Pack - AdventureWorks
Microsoft provides a sample database for various workload types like OLTP, Data Warehouse, and Lightweight workloads for each release of SQL Server. This sample database is called AdventureWorks. This dashboard shows data from the AdventureWorks database. There are ten tiles, and each tile pulls and formats data differently for each visualization.
Since each release of SQL Server results in a new version of AdventureWorks, you may need to make a few alterations to the data for visualization purposes. For example, the database doesn’t have any current data in some cases. The initial target for this dashboard was the AdventureWorks 2017 dataset. In several instances, the data for the tile was duplicated so that the graph appears continuous for visualization purposes.
Import the Microsoft AdventureWorks datasets from: https://docs.microsoft.com/en-us/sql/samples/adventureworks-install-configure?view=sql-server-ver15&tabs=ssms
Replace the connection string in each of the ten SQL tiles with the connection string to your own OperationsManagerDW database.
Open the connection panel.
Enter the connection string to your own OperationsManagerDW database, for example
Data Source=fqdn.site.domain.com;Initial Catalog=OperationsManagerDW;Integrated Security=True
Publish the dashboard.
