Data Streams
What is a Data Stream?
How do I get Data Streams?
Pre-configured data streams - some data sources come with pre-configured data streams that are indexed when you add the data source.
Configurable data streams - some data sources allow you to create new data streams using a form.
Advanced users can also write their own custom data streams (or edit a data stream created from a configurable data stream) see Custom Data Streams.
Using Data Streams
When adding or editing a tile on a dashboard you need to select a data stream, objects and visualization. See Dashboards
Help with configuring data streams specific to your data source can be found in each specific data source article:
List of documentation for data source plugins available
See also Scripts
Data Stream Shaping
Filtering
Data can be filtered according to whether data in a column meets or does not meet specified text or numerical value conditions. Depending on the data you are filtering, available options include: Equals, Not equals, Contains, Doesn't contain, Less than, Greater than, Before now, After now, Is empty, Is not empty.
Dates can be filtered by Before now or After now (e.g. to show overdue orders). Text matching is case sensitive.
You are able to add multiple filter conditions. Available options are:
AND – all conditions must be satisfied (e.g.
Status-Equals-ClosedANDType-Equals-Question).OR – any condition can be satisfied (e.g.
Status-Equals-PendingORStatus-Equals-Closed).
Grouping
For example, for AWS cost data you might Group bylabel, choose Aggregation typeTotal with Aggregation columnAmount, to show a table or bar chart of cost per label.
Which columns are available depends on the data stream you chose.
Bucket by
If you group by a time column, and further grouping is possible, then the Bucket by dropdown will appear, which allows you to control how the time data is grouped, for example by hour, day, month etc.
Aggregation type and column
Using this dropdown you can choose how to summarize your data, for example as a count, average or total.
For example, for a Bar Chart of ticket data you might Group by Date created, choose Bucket byDay with Aggregation type Count, to show a line graph of tickets per day. Or for a Bar Chart of Azure Resource Group cost you might Group byTimestamp, Bucket byDay, Aggregation typeTotal and Aggregate columnCost.
Sorting
