After installing Dashboard Server you will be prompted to login and enter a license activation key. You will have been emailed an activation key (often called a license key), which is then activated against a Dashboard Server installation.
Where do I find my v5 activation key?
Free trial
Purchased Dashboard Server
Types of license keys
| Trial license | This license allows for unlimited users and all features for a 30 day evaluation in your own environment and is available from here |
| Primary Production license | |
| Secondary license | This license should only be used for any subsequent servers in a multi-server / high availability / load balanced environment (see Enabling High Availability |
| Test & Development license | This license is for your test environment so that you can experiment with configuration changes and new versions without affecting production. It is included free of charge with a purchase |
Dashboard Server v3 customers
If you are upgrading from v3 to v4 you should request a v4 evaluation license before starting your v4 installation. This will allow you to perform any upgrade testing and user acceptance testing, prior to going live and switching your production use to v4. Without this license you will be able to install v4 and perform an upgrade assessment, but unable to then activate the product and start testing.
Take a moment to read How to migrate from Dashboard Server SCOM Edition v3 to v4 for important considerations regarding how to upgrade from v3 to v4.
Once you are ready to move to v4 in production, enter your Primary license key into the Switchover portal to convert all your existing v3 licenses to v4 licenses which can be used to activate v4. From that point you will have 3 months to run v3 and v4 side-by-side in production, before the v3 instance is no longer supported and you will be in violation of the SquaredUp EULA.
Activating Dashboard Server when the server does not have internet access
Browse to
http://SquaredUpServer/SquaredUpv[Version Number]/activationto get to your server's activation screen, for examplehttp://SquaredUpServer/SquaredUpv5/activation(where
SquaredUpServeris the name of the server where Dashboard Server is installed).Log in as a SCOM Admin.(see Types of users in Dashboard Server).
Click on offline activation. If Dashboard Server is already activated the link will show as offline reactivation.
If you see a message that the maximum number of activations has been exceeded see "License already activated" or "Maximum activations reached" or contact SquaredUp Support.
You may receive this error if using your v3 activation key on v4, please see How to migrate from Dashboard Server SCOM Edition v3 to v4. Click Download license file to download the license activation .bin file.
http://SquaredUpServer/SquaredUpv5/InstallLicense, and log in as a SCOM Admin user.Once the file has uploaded click Next and then complete the setup wizard.
If you uninstall and reinstall on the same server you can reuse the same .bin file by browsing to http://SquaredUpServer/SquaredUpv5/InstallLicense. The .bin file cannot be used on a different server. A Dashboard Server v2 .bin file will not work with Dashboard Server v4 or v5.
