How to run SCOM tasks
About SCOM tasks
SCOM tasks are tasks that can be executed for single objects, for example displaying the object's account settings. The tasks in Dashboard Server are similar to the tasks you find on the tasks pane in the SCOM console.
Which tasks are available depends on the object and the management packs that are installed. Only users with the correct SCOM access will be able to run the task (see How do SCOM roles affect what users can do in Dashboard Server?).
There are two different ways to run SCOM tasks in Dashboard Server:
Running tasks on dashboards or perspectives in the SCOM Task tile
Running tasks in the tile allows you to show the results of a SCOM task in a tile on a dashboard or perspective. Tasks in the SCOM Task run every time the dashboard refreshes (by default every minute).
Running tasks directly from a dashboard or perspective via a button
You can run tasks directly from a dashboard or perspective just by clicking a button. Tasks that are executed via a button only run when the button is clicked.
On perspectives, you can run any task that is available for that object with the task button at the top of the perspective.
How to run a task on a perspective with the task buttonGo to the object you want to run the task for and choose any of the available perspectives.
Click on the task button at the top of the perspective.
Now a dropdown menu with all available tasks opens.
Choose the task you want to run from the dropdown menu.
Some tasks let you override parameters, for example the time until the task runs into a timeout. Which parameters are available depends on the task.
If you want to override parameters for the task, click add under override parameters and enter your settings.
Click execute to run the task.
A new sections opens and displays the result of the task. The results are visible until you close the section or leave the page.
On dashboards and perspectives, you can create an action button for a specific task.
What is an action button?Action buttons are customized buttons that you can add at the top of a dashboard
or perspective .
How to create an action button for a specific taskFor dashboards: Go to the dashboard where you want to add the action button.For perspectives: If you want to add the action button to a specific perspective, go to
an object that contains the perspective and choose this perspective. If you want to add the action button to all perspectives of a specificclass of objects , go toan object that is a member of this class .Click on the edit button to go into edit mode.
Open an internal link
An internal link within your Dashboard Server instance.
For example, when you want to link from an object's perspective to a dashboard that is relevant for that object. Internal links use only the part of the URL that comes after .../SquaredUpv[version number]/. For example, if the full URLÂ to a dashboard is https://mysquaredup.com/SquaredUpv5/page/dashboard-enterprise-applications, you need to use /page/dashboard-enterprise-applications.Open a web link
Execute a SCOM task
You can run a SCOM task on an object.
If you selected the action type "task":
For dashboards: Enter the object you want to run the task on. While you are typing, you'll get suggestions for matching objects. Then select the task you want to run from the dropdown.
For perspectives: Select the task you want to run for the object you are currently viewing.
Take care to add task buttons to a relevant perspective so the button doesn't appear for objects where it will not run. For example, if you add the Display Server Statistics task to a button on the Monitored Entity perspective then it will show for all objects, but when if you try to run it when you are viewing an application you will get a task failed error message because server statistics cannot be shown for an application.
If you leave the checkbox activated, the action button will be visible only on this one perspective.If you deactivate the checkbox, the action button will be visible on all perspectives for all objects of the same class as the object you are currently viewing.
For task action buttons: All users with the correct SCOM access will be able to run the task with the action button. Clicking the button will display the results of the task at the top of the page. The results stay there until you close them or go to another page.
5 minute Video
This 5 minute video 'Dashboard actions' describes how to create and edit actions on a dashboard or perspective:
