How to scope tiles
The scope of a tile defines for which
How to scope tiles on dashboards
For some tiles on dashboards, defining a scope is mandatory. For other tiles, defining a scope is optional. For example, the API tile doesn't need a scope, but you can use the scope to filter the results further.
Options for scoping tiles on dashboards
| List | List allows you to select one or more objects or groups. You can add multiple Tip: Start typing and after two characters you'll see suggestions that match the name appear. By default searching will look for the top 10 items containing the words listed in the search. If you wish to create a more specific search you will need to use wildcards (*). If you place a wildcard after the term you are looking for, it will find all the objects which start with that word searched and any terms that may follow. If you place a wildcard at the start of the search term, it will look for objects that contain the searched word and also have terms before that word. If you enclose your searched term in wildcards it will look for objects which contain the searched word, this object will not begin or end with the term searched. | ||||||||||||||||||||||||||||||||||||
| Group | Group allows you to select members of a specific group. Only one group can be selected. | ||||||||||||||||||||||||||||||||||||
| Advanced | Advanced allows you to select a group, class or both. You must at least define either a group or class. You can define both. You can also use criteria to narrow down your selection. Group: Same as the group option above. Class: Class equates to the target class within SCOM. As you type the dropdown will be populated with suggestions of matching classes from SCOM, from which you can select the required class. Criteria: Criteria allows you to create an expression to further refine the scope. | ||||||||||||||||||||||||||||||||||||
For more information see: | |||||||||||||||||||||||||||||||||||||
Tips and scope examples
| What you want to select | What to use as a scope |
| All your Distributed Applications (DAs) | In the advanced section, use a class of either service (system.service) or user created distributed application |
| Only your Enterprise Applications (EAs) | In the advanced section, use a class of Enterprise Application (Base) |
FAQs
I'm missing certain
Dashboard Server adheres to SCOM Role Based Access Control (RBAC). This means users will only see in Dashboard Server what they are allowed to see in the SCOM. Any SCOM user can log on to Dashboard Server and RBAC will be applied. See How do SCOM roles affect what users can do in Dashboard Server?.
Only for Performance and Matrix tiles: Why do I get the error "No values found for the given metric for the last <time period> at the resolution '<raw/hourly/daily>'"?
You may get this message returned if you change the scope after setting the metric.
Symptoms
A Performance tile or Matrix tile shows no graph (graph tile is blank) or an error similar to the following:
The server encountered a problem whilst processing the request.
No values found for the given metric for the last <time period> at the resolution 'raw/hourly/daily'.
Cause
This error indicates that there is no data to show. There are several reasons why there may not be any data:
- No data is being collected.
- The SCOM collection rule is saving data to the Operations Manager database, but not to the Data Warehouse database.
- For the chosen timeframe there is no data.
- For the chosen scope and metric there is no data.
- The group specified contains only subgroups and you have not specified, or have removed, the class.
Procedure
Install the latest version of Dashboard Server.
Check the Data Warehouse connection.
If this message is shown for all performance graphs in Dashboard Server then you should check that Data Warehouse specified is correct.
Check data is being collected.
Dashboard Server uses data from the Data Warehouse database. If the data is available in SCOM this means the data is being collected and stored in the Operations Manager database. SCOM Reporting uses the Data Warehouse database, so if the data appears in a report then it is in the Data Warehouse.
How to trigger the workflows to collect dataFlush the health service state and cache to trigger the workflows to collect the data, either using SCOM or Dashboard Server.
To do this in Dashboard Server, browse to the object in Dashboard Server, then:
- Click on the Monitored Entity perspective.
- Click on Health Service in the Children section.
- Click the task button at the top of the page.
- Select the task Flush Health Service State and Cache.
- Click execute.
Change the timeframe.
Change the page or tile timeframe, to see if there is data over a different period of time.
There may be no data points available if you are using hourly data and looking at the last 1 hour (metric > timeframe is set to hourly and the tile or page timeframe is set to last 1 hour), or using daily data and looking at the last 24 hours (metric > timeframe is set to daily and the tile or page timeframe is set to last 24 hours).
When the timeframe section has use page timeframe selected the tile will use the page timeframe.
When the timeframe section has specific timeframe selected the tile will use the timeframe specified in the tile timeframe section. Only SCOM administrators or Team Folder authors/owners can edit the tile tileframe.
Tile timeframe:
Dashboard Server uses raw data by default as long as it is available for the whole reporting timeframe, then it will use hourly, and when that is not available for the timeframe it will use daily data. Whether raw or hourly data is available for the whole timeframe will depend on your Data Warehouse data retention settings. Using the default SCOM data retention settings means that Dashboard Server timeframes of 1 week or less will probably be using raw data, for timeframes between 30 days and 12 months Dashboard Server will be probably be using hourly data. The SCOM data retention settings may well have been changed from the default. For more information see How to optimise the Data Warehouse - 5 Point Plan - 4. Data Retention.
Check the metric.
The quickest way to check the metric is correct, is to clear the existing metric and use the down arrow button on the keyboard to view all the metrics available for the scope you have chosen.
You may get the
No values found for the given metricmessage returned if you change the scope after setting the metric.
How to scope tiles on perspectives
General advice for scoping tiles on perspectives
Remember that a scope for tiles on perspectives usually has to be fitting for multiple different objects. You always have to consider:
For which objects will this perspective be visible? (determined by the target of the perspective)
Is the scope I am configuring for a tile appropriate for all objects the perspective will be visible on?
Example:
You create a perspective with the target "class: Windows Server". The perspective will therefore be visible for all objects of the class Windows Server.
Now you create a tile on the perspective and scope it to "this object's children of class: Windows Server 2016 Logical Disk". This means that when you view a 2016 Windows server, you'll see data about the server's logical disks in the tile. But when you view a 2012 Windows Server the tile will show no data because the tile's scope is limited to logical disks on 2016 servers. Instead of picking "Windows Server 2016 Logical Disk" you should pick "Windows Server Logical Disk" to make the tile adjust to any object that uses the perspective.
There are two different sets of options when scoping tiles on perspectives. It depends on the tile you want to scope which set of options you'll see.
Suggestions
This /<YourApplicationName> Map / ... / Windows ComputerThe above will scope the tile to all the objects of class Windows Computer on this EAs map.
This / FinanceXS / ... / Windows Computer. Once chosen this scope will show all the Windows computers shown on the applications map.
Click on the text
<YourApplicationName> Map (children)which is your first scope step. This will expand the scope step so you can edit it.
<YourApplicationName> Mapby clicking the cross x next to it.
Start typing
Enterprise Application - Mapand select this from the list to add this class. This is so that this tile scope will work for all EAs, rather than just this one EA.
- The scope is now configured to show all the Windows computers on the EA's map, whichever EA you happen to be viewing with the perspective.
A sibling of an object is any object of the same class that is hosted by the same parent.
| This object | The dynamic scope will be resolved to the object currently viewed. "this object" option which does NOT mean the actual one object like for the target setting but the relative object I'm looking at |
This / child / child / class of object | The dynamic scope will be resolved to children of the object currently viewed. You select objects of a particular class that are contained in path. The class of the objects you are selecting is stated at the end of the path. |
| This / * | The dynamic scope will be resolved to children of the object currently viewed. If a path ends with a wildcard (*) it means that you select all objects of any class within the path. Technically it means that we fill the class field with the class "logical entity" since every object in SCOM has this class, it is a "base" class Example: |
This / child / ... / class of object | The dynamic scope will be resolved to children of the object currently viewed. If a path contains an ellipsis (...) it means that you select objects of a particular class that are contained in all of the objects that are contained in the path preceding the ellipsis. The class of the objects you are selecting is stated at the end of the path. Example:
Parent class of object | The dynamic scope will be resolved to parents of the object currently viewed. |
Sibling class of object | The dynamic scope will be resolved to siblings of the object currently viewed. |
| Show more triangle next to a suggestion |
Custom
At the top, you'll see the name of the object you are currently looking at. Now you can choose if you want to pick parents or children of that object, and if this parent or child relation should be considered only one level up or down the SCOM model or through all levels.
Class:
Criteria:
Class:
Criteria:
Other specific objects
Since the power of perspectives is that their tiles can show data for different
The Alerts and the SCOM task tile have slightly different options than other tiles because they require different settings.
This object
Relative objects
Class:
Criteria:
Note for SCOM task tiles:
