How to use the Grid Designer
The Grid designer is available in the grid columns panel in
Grid visualizations. It allows you to easily add, hide, order, and customize columns of data that may come from any internal or external source.
Hiding a column
By default, when you configure a tile all columns will be displayed. To hide a column, simply click hide for each column you wish to hide.
Restoring hidden columns
If you have previously hidden some columns that you now want restored, you can click show all columns to show visible and hidden columns (the toggle will now read show visible columns only). Columns that are currently hidden will be grayed out and have the show option instead of hide.
Tip: Filtering columns in your query
The column modifications are performed client-side, so it's still most efficient to filter the columns directly in your query or script
Ordering columns
Changing the column order couldn't be easier, simply click and drag the gray ☰ icon to the left of the column name.
Changing the name of a column
If you want to change a column name, simply click on the existing column name in the grid options panel and enter the new name.
To restore the original name, simply delete your updated name and the column will revert to its original name.
Changing the way the data in a column is displayed
To format the way the data in a column is displayed, click edit to the right of a column to display the custom template box. You can then type your standard Dashboard Server 'mustache' syntax and click on done when you have the column looking exactly how you want it. If you want to preview the results before you're done, click anywhere outside the text box while editing it.
A { } icon will appear next to the column edit option to indicate that a custom template has been applied.
The mustache syntax is great for converting numbers, adding units, highlighting key values or performing any other customizations you may need. For more information on mustaches see How to use Custom Labels.
Original property name:
Adding custom columns
You can dynamically construct new columns based on the data returned by your tile, which is invaluable when dealing with data sources that only support simple data retrieval, or where the API does not return data in a simple tabular form (such as many JSON based Web APIs).
To add a custom column:
- Click the add button near the bottom of the grid columns panel.
- Click the column name and change the name from customcolumn1 to the name you want to give the column.
- In the data key path box, enter the (original) name of the column or path to the desired property in the returned data (this will depend on the API you are returning data from). If you need to access the values of multiple columns (i.e. concatenating two columns together) simply leave the box empty.
- Optionally, if you want to customize the display of the column, you can enter a mustache in the custom template box
- Click done when you have finished.
Custom columns have a pencil icon in the grid options panel to indicate they have been added by a dashboard author.
Example
In this example, we are going to customize the output of a SCOM task from the Data On Demand management pack that displays CPU process information. This will include hiding columns which may not be interesting, reformating some data for legibility, and separating the path column into separate folder and executable columns, so that a long path doesn't make it hard to see what program is being run.
- Add a new tile to a dashboard or windows server perspective. If using a dashboard, on the scope panel specify a valid Windows computer.
- Click on SCOM Task and then On-Demand Task (Grid). Click next.
- In the task config panel select List Processes (Data On Demand) as the task to execute.
- Click hide next to sessionId, handles, parentPid and threads.
- Click add and select Format in the override parameters dropdown. Enter
csvand click apply changes (execute). Click next twice. - Rename cpuPercent to
CPU Usageby clicking on it's name in the grid columns panel. - Click edit to the left of your CPU Usage column. In the custom template column enter `{{value}}%' to add a percent symbol to the value. Click done.
- Rename the privateBytes column to
Private MBand click edit. In the template box enter{{Math.round(value/1048576)}}. Click done. - Rename the path column to
Folder. Click edit and enter{{value.substring(0,value.lastIndexOf('\\'))}}. Click done. - Click add to add a new custom column. Rename the column from customcolumn1 to Executable. In the path box enter
pathand in the custom template box enter{{value.slice(1+ value.lastIndexOf('\\'))}}. Click done. - Click and drag the ☰ icon to the left of the Executable column above the Folder column.
- Click the orange done button to finish editing the tile.
| Show Absolute |
| Show Time |
| Without Suffix |
| With Prefix |
Examples:
