Theme Personalization
Theme Personalization allows users to view Dashboard Server in either dark theme or light theme.
Azure Edition uses dark theme by default.
Setting your individual theme
You can decide if you want to view Dashboard Server Azure Edition in dark theme or light theme. The individual theme setting only affects the way Dashboard Server looks to you, not how it looks to other users.
Go to the top right-hand menu ☰ > personalization.
Toggle the dark theme button to on or off.
When the dark theme button is set to off, you'll see Dashboard Server in light theme. When it is set to on, you'll see Dashboard Server in dark theme.
Setting the theme for all Open Access Dashboards
Open Access dashboards in Azure Edition default to dark theme
You can decide if you want Open Access dashboards to be viewed in dark theme or light theme. This is a global setting which controls the theme for all Open Access dashboards and all users who navigate to any of the Open Access URLs will be affected by this setting.
Go to the top right-hand menu ☰ system > Open Access.
When the dark theme button is set to off, all Open Access dashboards are viewed in light theme. When it is set to on, all Open Access dashboards are viewed dark theme.
