Best Practices for Security
General security best practices
The following list gives you some general best practices for securely administering a web application like Dashboard Server Azure Edition. The list gives you recommendations only and is not comprehensive.
Authentication
The best way to ensure secure authentication is to choose multifactor authentication. Requirements:
You need to enable Windows (SSO) authentication.
You need to set up multifactor authentication for your Active Directory. Learn more about the different ways to do that in this external article: https://www.microsoft.com/en-gb/security/business/identity-access-management/mfa-multi-factor-authentication
Check your Active Directory security policies.
In addition to your existing Active Directory Password Policy, you should define an Account Lockout Policy. While your Password Policy ensures that your passwords are safe, an Account Lockout Policy defines what happens when the password is incorrectly entered. It secures accounts against brute force attacks by locking an account after a defined number of false login attempts.
Recommended Active Directory password policy settingsYou can find a detailed description about Active Directory Password Policy Settings in this external article: https://activedirectorypro.com/how-to-configure-a-domain-password-policy
Password Policy Setting Recommended Setting Enforce Password History 24 Maximum password age not set Minimum password age not set Minimum password length 14 Password must meet complexity Enabled Store passwords using reversible encryption Disabled
How to define an Active Directory Account Lockout PolicyOpen the Group Policy Management Console.
Go to Domains > [Your domain] > Group Policy Objects.
Right click the domain policy you want to edit.
In the domain, go to Computer Configuration\Policies\Windows Settings\Security Settings\Account Policies\Account Lockout Policy.
Enter the following settings:
Setting Description Recommended Value Account lockout duration This is how long the account will remain locked for – the higher this value, the longer it is between attempts 60 minutes Account lockout threshold This is the number of attempts before the account will lock 3 invalid logon attempts Reset account lockout counter after Defines when the failed attempt counter will reset (meaning that x incorrect attempts within this period will cause the lockout)
30 minutes The Account Lockout Policy is now set.
Disable outdated TLS and SSL.
Dashboard Server uses TLS 1.2, but offers connections with TLS 1.0 and TLS 1.1, which are deprecated. Outdated TLS and SSL can pose a security risk and can be disabled to make using Dashboard Server more secure.
Note: Disabling TLS 1.0 and TLS 1.1 can cause compatibility issues which might restrict older devices from being able to connect to the server.You can change the settings manually via script or via the IIS Crypto tool.
How to change TLS and SSL settings manually via scriptRecommended settings:
Disable TLS 1.0
Disable TLS 1.1
Disable SSL 2.0
Disable SSL 3.0
Enable TLS 1.2
Run the following PowerShell script on the server Dashboard Server is installed on to disable TLS 1.0:
Copy#DISABLE TLS 1.0
$RegPath = "HKLM:\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Protocols"
Set-Location HKLM:
if (Test-Path"$RegPath\TLS 1.0")
"TLS 1.0 YEP"
if (Test-Path"$RegPath\TLS 1.0\Client")
"CLIENT YEP"
Remove-Item -Path "$RegPath\TLS 1.0" -Recurse
New-Item -Path "$RegPath" -Name "TLS 1.0" –Force
New-Item -Path "$RegPath\TLS 1.0" -Name "Client" –Force
New-ItemProperty -Path "$RegPath\TLS 1.0\Client" -Name DisabledByDefault -Value 1 -Type DWORD -Force | Out-Null
New-ItemProperty -Path "$RegPath\TLS 1.0\Client" -Name Enabled -Value 0 -Type DWORD -Force | Out-Null
New-Item -Path "$RegPath\TLS 1.0" -Name "Server" –Force
New-ItemProperty -Path "$RegPath\TLS 1.0\Server" -Name DisabledByDefault -Value 1 -Type DWORD -Force | Out-Null
New-ItemProperty -Path "$RegPath\TLS 1.0\Server" -Name Enabled -Value 0 -Type DWORD -Force | Out-Null
Restart-Computer -ConfirmRun the following PowerShell script on the server Dashboard Server is installed on to disable TLS 1.1:
Copy#DISABLE TLS 1.1
Set-Location HKLM:
if (Test-Path"$RegPath\TLS 1.1")
"TLS 1.1 YEP"
if (Test-Path"$RegPath\TLS 1.1\Client")
"CLIENT YEP"
Remove-Item -Path "$RegPath\TLS 1.1" -Recurse
New-Item -Path "$RegPath" -Name "TLS 1.1" –Force
New-Item -Path "$RegPath\TLS 1.1" -Name "Client" –Force
New-ItemProperty -Path "$RegPath\TLS 1.1\Client" -Name DisabledByDefault -Value 1 -Type DWORD -Force | Out-Null
New-ItemProperty -Path "$RegPath\TLS 1.1\Client" -Name Enabled -Value 0 -Type DWORD -Force | Out-Null
New-Item -Path "$RegPath\TLS 1.1" -Name "Server" –Force
New-ItemProperty -Path "$RegPath\TLS 1.1\Server" -Name DisabledByDefault -Value 1 -Type DWORD -Force | Out-Null
New-ItemProperty -Path "$RegPath\TLS 1.1\Server" -Name Enabled -Value 0 -Type DWORD -Force | Out-Null
Restart-Computer -ConfirmRun the following PowerShell script on the server Dashboard Server is installed on to disable SSL 2.0:
Copy#DISABLE SSL v2.0
Set-Location HKLM:
if (Test-Path"$RegPath\SSL 2.0")
"SSL 2.0 YEP"
if (Test-Path"$RegPath\SSL 2.0\Client")
"CLIENT YEP"
Remove-Item -Path "$RegPath\SSL 2.0" -Recurse
New-Item -Path "$RegPath" -Name "SSL 2.0" –Force
New-Item -Path "$RegPath\SSL 2.0" -Name "Client" –Force
New-ItemProperty -Path "$RegPath\SSL 2.0\Client" -Name DisabledByDefault -Value 1 -Type DWORD -Force | Out-Null
New-ItemProperty -Path "$RegPath\SSL 2.0\Client" -Name Enabled -Value 0 -Type DWORD -Force | Out-Null
New-Item -Path "$RegPath\SSL 2.0" -Name "Server" –Force
New-ItemProperty -Path "$RegPath\SSL 2.0\Server" -Name DisabledByDefault -Value 1 -Type DWORD -Force | Out-Null
New-ItemProperty -Path "$RegPath\SSL 2.0\Server" -Name Enabled -Value 0 -Type DWORD -Force | Out-Null
Restart-Computer -ConfirmRun the following PowerShell script on the server Dashboard Server is installed on to disable SSL 3.0:
Copy#DISABLE SSL v3.0
Set-Location HKLM:
if (Test-Path"$RegPath\SSL 3.0")
"SSL 3.0 YEP"
if (Test-Path"$RegPath\SSL 3.0\Client")
"CLIENT YEP"
Remove-Item -Path "$RegPath\SSL 3.0" -Recurse
New-Item -Path "$RegPath" -Name "SSL 3.0" –Force
New-Item -Path "$RegPath\SSL 3.0" -Name "Client" –Force
New-ItemProperty -Path "$RegPath\SSL 3.0\Client" -Name DisabledByDefault -Value 1 -Type DWORD -Force | Out-Null
New-ItemProperty -Path "$RegPath\SSL 3.0\Client" -Name Enabled -Value 0 -Type DWORD -Force | Out-Null
New-Item -Path "$RegPath\SSL 3.0" -Name "Server" –Force
New-ItemProperty -Path "$RegPath\SSL 3.0\Server" -Name DisabledByDefault -Value 1 -Type DWORD -Force | Out-Null
New-ItemProperty -Path "$RegPath\SSL 3.0\Server" -Name Enabled -Value 0 -Type DWORD -Force | Out-Null
Restart-Computer -ConfirmRun the following PowerShell script on the server Dashboard Server is installed on to enable TLS 1.2:
Copy#Enable TLS 1.2
Set-Location HKLM:
if (Test-Path"$RegPath\TLS 1.2")
"TLS 1.2 YEP"
if (Test-Path"$RegPath\TLS 1.2\Client")
"CLIENT YEP"
Remove-Item -Path "$RegPath\TLS 1.2" -Recurse
New-Item -Path "$RegPath" -Name "TLS 1.2" –Force
New-Item -Path "$RegPath\TLS 1.2" -Name "Client" –Force
New-ItemProperty -Path "$RegPath\TLS 1.2\Client" -Name DisabledByDefault -Value 0 -Type DWORD -Force | Out-Null
New-ItemProperty -Path "$RegPath\TLS 1.2\Client" -Name Enabled -Value 1 -Type DWORD -Force | Out-Null
New-Item -Path "$RegPath\TLS 1.2" -Name "Server" –Force
New-ItemProperty -Path "$RegPath\TLS 1.2\Server" -Name DisabledByDefault -Value 0 -Type DWORD -Force | Out-Null
New-ItemProperty -Path "$RegPath\TLS 1.2\Server" -Name Enabled -Value 1 -Type DWORD -Force | Out-Null
Restart-Computer -ConfirmRun the following script in case you need to undo all changes you made to TLS and SSL:
Copy#Revert Changes
Remove-Item'HKLM:\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Protocols\SSL 3.0\' -Recurse
Remove-Item'HKLM:\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Protocols\TLS 1.0\' -Recurse
Remove-Item'HKLM:\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Protocols\TLS 1.1\' -Recurse
How to change TLS and SSL settings and avoid 64-bit block ciphers via IIS CryptoDownload IIS Crypto from Nartac Software.
https://www.nartac.com/Products/IISCrypto/DownloadOpen IIS Crypto and go to the Templates tab.
Choose the PCI 3.2 option from the drop-down.
The PCI 3.2 option provides PCI (Payment Card Industry) compliance.
This setting will block the following client and server protocols:Multi-Protocol Unified Hello
PCT 1.0
SSL 2.0
SSL 3.0
TLS 1.0
TLS 1.1
TLS 1.2 will still be enabled.
The following ciphers will be disabled:
NULL
DES 56/56
RC2 40/128, 56/128, 128/128
RC4 40/128, 56/128, 64/128, 128/128
Check the settings in the Schannel and Cipher Suites tabs to make sure you're happy with all settings.
Check the Reboot box at the bottom of the tool and click Apply.
Remove unwanted HTTP response headers.
How to remove HTTP response headers using the URL rewrite moduleThere are 3 response headers you should remove for security reasons:
Server - Specifies web server version
X-Powered-By - Indicates that the website is "powered by ASP.NET."
X-AspNet-Version - Specifies the version of ASP.NET used
Open IIS Manager and click on your Dashboard Server instance.
Click on View Server Variables in the Actions panel on the right hand side.
Click the Add button in the Actions panel.
Add 3 new variables, one for each header you want to remove:
You can see the newly created server variables in the list of allowed variables.
Click the Back to rules button in the Actions panel.
Click the Add rule(s) button in the Actions panel.
Create 3 new rules, one for each header you want to remove. Choose Outbound rules > Blank rule for each rule.
Enter the following settings for each rule:
Precondition: None
(use RESPONSE_X-POWERED-BY and RESPONSE_X-ASPNET-VERSION for your other two rules)Variable value: Matches the pattern
Using: Regular Expressions
Pattern: .*
(read "dot asterisk", meaning "match any content")Action type: Rewrite
Leave the other settings to default.
Click the Apply button in the Actions panel.
Block requests without a Host header.
How to block requests without a Host headerOpen IIS Manager and click on your Dashboard Serverinstance.
Click on Add rule(s) in the Actions panel on the right hand side.
Choose Inbound rules > Request blocking.
Enter the following settings for the rule:
Pattern (Host Header): .+
(read: "dot plus", meaning "match one or more of any characters")Using: Regular Expressions
How to block: Abort request
Click OK to save the rule.
Use secure cookies.
By default, Dashboard Server works over HTTP and requires a manual setup to enable HTTPS. If you use secure cookies, they will be sent to the browser with the
secureflag, which means the browser will never send the cookies over HTTP.Since cookies won't be send over HTTP when the cookie setting is set to
requireSSL="true", Dashboard Server will not function over HTTP with this setting. Your Dashboard Server instance needs to be setup with HTTPS.
How to use secure cookiesFind the
web.configfile located in the Dashboard Server folder.
For example, for Dashboard Server v5 the default folder location isC:\inetpub\wwwroot\SquaredUpv5and for v4 C:\inetpub\wwwroot\SquaredUpv4Create a backup of the
web.configfile by copy and pasting the file to a different location.Open the original
web.configfile with Notepad.- Find the following line:
<httpCookies httpOnlyCookies="true" />
and extend it to:
<httpCookies httpOnlyCookies="true" requireSSL="true" />
Save the
web.configfile.Since cookies won't be send over HTTP when the cookie setting is set to
Prevent embedding via iframe.
By default, Dashboard Server can be embedded in other pages via iframe. This applies to authenticated Dashboard Server links (a dashboard that needs signing it to be viewed) as well as unauthenticated links (Open Access dashboards). To prevent clickjacking, you can restrict embedding.
You have two options to restrict embedding:
prevent all embedding for authenticated and unauthenticated links (DENY option)
restrict embedding so that Dashboard Server content can only be embedded within Dashboard Server (SAMEORIGIN option)
How to restrict embedding for Dashboard ServerOpen IIS Manager and click on your Dashboard Server instance.
In the main panel, double-click on HTTP response headers.
Check the list of headers for a header named X-Frame-Options. If the header is not in the list, add a new header named X-Frame-Options.
Set the value for the X-Frame-Options header to
DENYorSAMEORIGIN.Embedding is now restricted according to the option you chose.
Security best practices for administering Dashboard Server Azure Edition
The following list gives you best practices for securely administering Dashboard Server Azure Edition.
PowerShell tiles:
PowerShell Run As accounts
PowerShell scripts are very powerful and can cause damage when not properly configured. Your Run As accounts contain the credentials a script uses to run as, which means the Run As determines the permissions a PowerShell script has when it is executed. When you are creating Run As accounts, you want to give your PowerShell scripts the minimum permissions needed so that they can do what you intended for them to do without giving them permissions that can be exploited and could lead to security risks.
Best practices for Run As accounts1) For all Run As accounts: Use a service account, not a user account for Run As accounts.
Do not use your own or anyone's personal user account for Run As accounts. Instead, create a new account that is not used by a specific person (a "service account"), but only used for running PowerShell scripts. Consider the permissions of this service account carefully.
Required permissions for service accounts:
The service account you use for Run As must have at least the following permission:
Allow log on locally
Note for Run As accounts if you are using any other application pool identity than NetworkServiceIf you don't use the default NetworkService as your application pool identity, you might see the following error message when using Run As accounts: A required privilege is not held by the client.
Why shouldn't you use user accounts for Run As accounts?The user credentials you enter for the Run As account are used to run all PowerShell scripts in tiles that use the Run As account. Once created, your Run As account can be used by other Dashboard Server administrators to run their scripts. By using your or any user's credentials, you lose control over which scripts are executed in the name of this user which can cause privacy issues. In addition to that, users often have more rights than a script would need. By using a user account with extensive permissions, scripts that use the Run As can exploit those permissions.
How to create a new Run As accountFrom the top right hand menu ☰ click system.
Go to the PowerShell tab.
In the Run As section, click on the + button to add a new Run As.
Enter a name and a description for your new Run As.
Note: Once you have saved the Run As account, you can't change its name anymore. You can always change the description.
Enter the user credentials you want to use for this Run As account.
Click save to save the new Run As account.
The Run As account is now available in PowerShell tiles and can be used to execute scripts.
2) We strongly recommend you change the Default Run As account to the credentials you want to use as the default Run As.
Every PowerShell tile needs a Run As and if you haven't created a Run As yet, tiles will use the Default Run As. The Default Run As uses the Dashboard Server app pool to run scripts. The Dashboard Server app pool account might grant too many permissions that are not needed for your scripts and can potentially damage your system, which is why using this default account is not recommended. Create a service account that you want to use for the Default Run As and change the Default Run As to use those credentials.
How to change the Default Run As accountFrom the top right hand menu ☰ click system.
You see the Default Run As. If you haven't changed the Default Run As account yet, you see a yellow icon indicating that the Run As uses the not recommended default setting "run as Dashboard Server app pool".
Click on the Default Run As to edit it.
As long as the Run as Dashboard Server app pool toggle is on, the Default Run As is read only.
Switch the Run as Dashboard Server app pool toggle to off.
Change the description to indicate that the Default Run As no longer uses the Dashboard Server app pool.
Enter the user credentials you want to use for the Default Run As.
Click save to save the changes.
The Default Run As profile now uses the user account you entered when executing scripts.
3) Consider disabling the option to use the Dashboard Server app pool for the Default Run As.
To make sure that the Dashboard Server app pool can't be used after you changed the Default Run As, you can disable the option to use the Dashboard Server App pool.
How to disable the "run as app pool" option for the Default Run As accountBy default, the toggle Run as Dashboard Server app pool is visible in the Default Run As account. By setting this toggle to on, the Default Run As can be (re)set to use the Dashboard Server app pool to run scripts. Dashboard Serveradministrators can disable the toggle to prevent that the Dashboard Serverapp pool can be used for running PowerShell scripts.
If you haven't already done it, change the Default Run As from using the Dashboard Server app pool to using the credentials you want to use.
Note: If you disable the toggle Run as Dashboard Server app pool while the Default Run As still uses the Dashboard Server app pool (toggle on), the credentials in the Default Run As will be empty and any PowerShell tiles using the Default Run As will show an error. You need to go into the Default Run As and enter the credentials you want to use to fix this issue.
How to change the Default Run AsFrom the top right hand menu ☰ click system.
notepad, and then right-click and select Run as administrator).In Notepad, open the
security.jsonfile from the Dashboard Server folder:...\User\Configuration\security.jsonIf the file doesn't exist, create it by following these steps and saving the file as
security.jsonat the end.
For example, for Dashboard Server v5 the default folder location isC:\inetpub\wwwroot\SquaredUpv5and for v4 C:\inetpub\wwwroot\SquaredUpv4Edit the JSON file to contain the following property:
Copy{
"enable-powershell-run-as-app-pool": false
}If the file already contains settings, then you will need to add a comma at the end of the previous line.
- Save the JSON file.
The toggle Run as Dashboard Server app pool is now disabled and hidden. It is not possible to (re)set the Default Run As to use the Dashboard Server app pool anymore.
4) Consider creating different service accounts for running different scripts, depending on what their purpose is and what permissions they need. Save each service account as a different Run As account in Dashboard Server.
Disable PowerShell V2.
PowerShell V2 has been deprecated and is now recognized as a security risk that can be used to run malicious scripts. Disable PowerShell V2 to prevent the risk of users being able to bypass various security measures.
How to disable PowerShell V2Run the following PowerShell script on the server Dashboard Server is installed on. The script checks if PowerShell V2 is enabled and disables it if it is enabled:
Copy#Checks to see if Powershell V2 is enabled. If it is, it will be disabled
$State = Get-WindowsOptionalFeature -Online -FeatureName MicrosoftWindowsPowerShellV2
$State.State
IF ($State.State -eq"Enabled") {
cls
Write-Output"Powershell V2 is enabled"
Write-Output"Disabling Powersell V2"
Disable-WindowsOptionalFeature -Online -FeatureName MicrosoftWindowsPowerShellV2Root
Write-Output"Powershell V2 has been disabled"
ELSE {
cls
Write-Output"Powershell V2 is already disabled"
Enable PowerShell script block logging for improved monitoring.
How to enable PowerShell script block loggingRun the following PowerShell script on the server Dashboard Server is installed on if you want to enable script block logging:
CopyCLS
$RegPath = "HKLM:\SOFTWARE\Wow6432Node\Policies\Microsoft\Windows\PowerShell\ScriptBlockLogging"
Set-Location HKLM:
if (Test-Path"$RegPath")
"PATH"
else
New-Item -Path $RegPath -Force
Set-ItemProperty -Path $RegPath -Name "EnableScriptBlockLogging" -Value 1 -Force
}If you want to disable script block logging again, run the following script:
Copy#Disable Script Block logging
Set-ItemProperty -Path $RegPath -Name "EnableScriptBlockLogging" -Value 0 -Force
Configure AppLocker or WDAC to control and restrict access to scripts, executables and libraries only trusted by Microsoft.
You can find more info in this external article: https://docs.microsoft.com/en-us/windows/security/threat-protection/windows-defender-application-control/wdac-and-applocker-overview
Disable the PowerShell tile feature if you don't need to use it.
How to disable the PowerShell tile featureBy default, the PowerShell feature is available, but Dashboard Server administrators can globally disable it. When the feature is disabled, any existing PowerShell tiles will still be visible to users as before but the scripts won't be executed anymore. Instead, PowerShell tiles will display the error message "PowerShell functionality is disabled". Administrators will still be able to create and edit PowerShell tiles, profiles and Run As accounts.
Copy{
"enable-powershell-execution": false
The PowerShell feature is now disabled. Scripts in existing PowerShell tiles won't be executed anymore.
Check the security settings in the
security.jsonfile.There are multiple settings you can define in the
security.jsonfile that affect Dashboard Server security. Check those settings and change them if needed.
How to access the security.jsonfileOn the SquaredUp server, run Notepad as administrator (Start, Run, type
Properties you can set in the security.json fileProperty Description enable-visio-svg-sanitization SVG files uploaded to the Visio tile are sanitized by Dashboard Server to prevent cross-site scripting (XSS) attacks, such as redirecting to a phishing site. If an SVG is failing to display correctly, then it is likely that certain tags are being removed by the sanitizer.
If you are unable to modify the original SVG then it is possible to disable SVG sanitization. This method is only available for Dashboard Server v4.2 and above. Please be aware that disabling this feature presents a security risk and that it affects all SVGs uploaded to Visio tiles across the whole of Dashboard Server.
Please ensure that if you choose to disable SVG sanitization, users are advised to remain vigilant and must be cautious of any strange behavior on pages containing uploaded SVGs.
Affected features: Visio tile
Possible values:
true,falseSecure option:
trueenable-embedded-scripts-whitelist For security reasons scripts cannot be run in Web Content tiles (iframes) in Dashboard Server v4.6 onwards.
If a site uses scripts, the web content tile might displaying nothing for that site, display the site in a poorly formatted manner, or there may be a message from the site itself indicating that it requires JavaScript to function correctly.
To embed another Dashboard Server dashboard using the Web Content tile you will need to whitelist your Dashboard Server site.
Affected features: Web Content tile
Possible values: websites in the format
https://squaredupserver1.squaredup.com/Secure option: no whitelisting
enable-powershell-execution Enables or disables the whole PowerShell feature (PowerShell tiles are turned off, no PowerShell script will be executed).
Affected features: PowerShell tile
Possible values:
false(if you are not using the PowerShell feature)enable-powershell-run-as-app-pool Enables or disables the ability to run PowerShell scripts as the Dashboard Server app pool.
Affected features: PowerShell Run As accounts
Possible values:
falseYou can copy the code template below and use it for your security settings in the
security.jsonfile.Make sure to replace the values with the values that match your desired settings!
Copy{
"enable-all-embedded-scripts": false,
"enable-embedded-scripts-whitelist": [
"enable-powershell-execution": true,
