CVE-2021-40095 - Reading arbitrary files
CVE:CVE-2021-40095
An issue was discovered in SquaredUp for SCOM 5.2.1.6654. The Download Log feature in System / Maintenance was susceptible to a local file inclusion vulnerability, leading to the ability to read arbitrary files on the server filesystems.
What should you do?
| Product | Affected versions | Resolved versions |
| SCOMÂ Edition | Versions earlier than 5.3.1 | 5.3.1 and later versions |
| Azure Edition | Versions earlier than 5.3.1 | 5.3.1 and later versions |
| Community Edition | Versions earlier than 5.3.1 | 5.3.1 and later versions |
Acknowledgement
| 10.11.2021 | Initial release |
