Atlassian StatusPage plugin
This data source returns data from any publicly accessible Atlassian StatusPage.
How to add an Atlassian StatusPage data source
Display Name:
Organization Name:
Enter the name of the StatusPage's organization.
Atlassian StatusPages follow the following format: https://OrganizationName.statuspage.ioNote: You don't need to enter the URL, just the
OrganizationName.Optionally, select whether you would like to restrict access to this data source instance. By default, restricted access is set to off.
Click Add.
