Atlassian Jira plugin
Monitor the Projects, Releases and Issues from your Jira Software environment.
Only the Jira Cloud offering is supported by this data source.
How to add an Atlassian Jira data source
Display Name:
Domain URL:
The domain for your Atlassian instance in the format
https://your-domain.atlassian.netUser Email Address:
Enter the email address of your Atlassian user account. You need to have access to that user account since you need to create an API token with the same user you entered here (see next step).
Here's how the email address (Atlassian user account) you use here influences which data will be returned:
For Confluence data source: If the user account doesn't have access to a space, the space won't be returned. If the user account has read-only access to a space, you'll get the pages in that space.
For the Jira data source: Even if the user account you use here has just read-only access to a project, the issues in that project will still be returned.
For the Jira Service Management data source: If the user account doesn't have access to any Jira Service Management service desks, nothing will be returned by the data source.
API Token:
Go to your Atlassian account, create an API token, and paste it in here. You can go directly to your Atlassian API tokens using this link: https://id.atlassian.com/manage-profile/security/api-tokens
Note: You need to create the API token with the same user account you used for the User Email Address field.
Tip: If you are using the Atlassian Confluence and the Atlassian Jira data source you can use the same token for both data sources.
Click Add.
Using the Jira data streams
Create a data stream using the configurable data stream see Creating a data stream using a configurable data stream
JQL Query
This data stream calls the /rest/api/3/search endpoint, and allows you to enter a custom JQL query.
In the tile editor, filter by the Atlassian Jira data source, select JQL Query from the data stream list and then click Next.
Enter a JQL Query, for example:
project={{key}}&updatedDate>='{{timeframe.startTime}}'
A mustache parameter is a dynamic value, the actual value will be inserted to replace the field in curly braces. For example, {{timeframe.start}} will insert the start time based on the timeframe configured within the tile, or {{name}} will insert the name of the object(s) in scope.
You can use properties of objects and write them in between curly braces e.g {{name}} to use them as mustache parameters. Whenever you use mustache parameters, you need to use a scope of objects that contain the property you're referencing.
For example, if objects of type "host" have a property called name, you can use {{name}}. This will resolve {{name}} to the value of the name property of the different "host" objects used in the scope.
Timeframe
An additional timeframe object is also available for mustache syntax.
Available properties of the additional timeframe object are as follows:
Property | Description | Example |
start | The start time of the timeframe in ISO format | 2022-05-10T16:00:00.000Z |
end | The end time of the timeframe in ISO format | 2022-05-11T16:00:00.000Z |
unixStart | The start time of the timeframe in Unix format (seconds) | 1652198400 |
unixEnd | The end time of the timeframe in Unix format (seconds) | 1652284800 |
interval | A fraction of the length of the timeframe in ISO interval format | PT15M |
startDate | The start time of the timeframe in yyyy-MM-dd format | 2022-05-10 |
endDate | The end time of the timeframe in yyyy-MM-dd format | 2022-05-11 |
startTime | The start time of the timeframe in yyyy-MM-dd HH:mm format | 2022-05-10 16:00 |
endTime | The end time of the timeframe in yyyy-MM-dd HH:mm format | 2022-05-11 16:00 |
