CircleCI plugin
Monitor the Pipelines and Workflows from your CircleCI environment.
How to add a CircleCI data source
Create a personal API token in CircleCI
Add the CircleCI data source to SquaredUp
Paste in the Personal API Token you created.
Install Sample Dashboards:
Data source access levels
Access Level:
Click Add.
