PagerDuty plugin
Monitor the Incidents and Alerts from your PagerDuty environment.
How to add a PagerDuty data source
Create an API key in PagerDuty
Add a PagerDuty data source to SquaredUp
Paste in the API key you created.
Optionally, enter the time zone to use for the returned data. This should be a string representing a recognized time zone in the format of the IANA time zone database, see PagerDuty: Time Zone. For example, you might enter
Etc/UTCfor Coordinated Universal Time.Install Sample Dashboards:
If you receive a warning that your Account does not have the Teams ability. Scoped OAuth requires: teams.read please contact PagerDuty or see PagerDuty: Teams.
