Prometheus plugin
The data source lets you monitor any metrics from your Prometheus environment using custom PromQL queries.The data source is available as a Cloud data source and also as an on-premises data source.
Note: This data source is of great use in addition to other data sources. It enables you to get different kinds of data and insights about objects that have been indexed by other data sources.
How to add a Prometheus data source
You will only need to configure and deploy an agent if you adding the Prometheus on-premises data source. If you want to add the Prometheus Cloud data source, you only need to follow the steps detailed in Add a Prometheus data source to SquaredUp.
Configure and deploy an agent
Enter the URL of your Prometheus instance.
Enter the API Token if it is required to access your server.
Select the agent Group from the list.
This is only required if you are configuring the Prometheus on-premises data source.
Click Add.
Using the Prometheus data streams
Creating a data stream using the configurable data stream (simplest option) see Creating a data stream using the configurable data stream
Write a custom data stream (advanced use) see Writing a custom data stream (advanced users)
PromQL
This data stream calls the /api/v1/query endpoint, and allows you to enter a custom query.
In the tile editor, filter by the Prometheus data source, select the PromQL data stream and then click Next.
You can either select the scoped PromQL data stream or the global PromQL data stream.
If you selected the scoped Prom QL data stream, select the objects you want to use and then click Next.
You do not need to do this if you have selected the global PromQL data stream.
Enter a Query, for example:
sum by (instance) (rate(kubedns_probe_dnsmasq_latency_ms_sum[1m])) / sum by (instance) (rate(kubedns_probe_dnsmasq_latency_ms_count[1m]))Mustache parameters are supported when scoped to an object.
Supports mustache parametersA mustache parameter is a dynamic value, the actual value will be inserted to replace the field in curly braces. For example,
{{timeframe.start}}will insert the start time based on the timeframe configured within the tile, or{{name}}will insert the name of the object(s) in scope.This data stream supplies scoped objects individually for mustache parameters. When there are multiple objects in scope this data source will send the query multiple times, once for each object. The results are then displayed together, for example in a single table.
You can use properties of objects and write them in between curly braces e.g
{{name}}to use them as mustache parameters. Whenever you use mustache parameters, you need to use a scope of objects that contain the property you're referencing.For example, if objects of type "host" have a property called
name, you can use{{name}}. This will resolve{{name}}to the value of the name property of the different "host" objects used in the scope.Ignore Timeframe:
Tick this checkbox if you wish to return a single scalar value rather than a table of results.
Click Save.
Go to Settings > Data Streams.
Click Add new Data Stream.
Choose the Data Source this Data Stream is for.
After you've chosen the data source a new field Entry Point appears.
Entry point and code:
What is an entry point?Each data stream uses an entry point, which can either be global (unscoped) or scoped, and this determines whether the data stream uses the tile scope.
To find out which entry point to select and get code examples for the Code field, see the help below.
Example 1: Using a Prometheus query
Which data stream do I have to select?
Prometheus Query (Unscoped)
Display Name
Mandatory
The internal name of the data stream. Can be used the refer to this data stream in a tile's JSON instead of using the data stream's internal ID.
dataSourceConfig Parameters
Query | Mandatory
Note: You can't use mustache parameters in the query since it doesn't use the |
Ignore Timeframe | Optional You can add the The dashboard timeframe is the current timeframe setting for a dashboard. Users can change the dashboard timeframe to see data for a different time span, for example, instead of showing data from "the last 12 hours" it can be changed to show data from "the last 7 days". Tiles can be configured to:
Tip: Indicate with the name of a tile if the tile's timeframe can be changed. For example, naming a tile "Performance during the last week" tells users that this tile always shows data for the last week. Naming a tile just "Performance" indicates to users that changing the dashboard timeframe will change the data. |
Example 2: Get CPU usage for a selected object from a GCP cluster
Note: This Data Stream requires a Google Cloud Platform data source which has to be configured to return information from a cluster.
Prometheus Query (Scoped)
Display Name
Mandatory
Query | Mandatory You can use mustache parameters in the query.
A mustache parameter is a dynamic value, the actual value will be inserted to replace the field in curly braces. For example, This data stream supplies scoped objects individually for mustache parameters. When there are multiple objects in scope this data source will send the query multiple times, once for each object. The results are then displayed together, for example in a single table. You can use properties of objects and write them in between curly braces e.g For example, if objects of type "host" have a property called |
Ignore Timeframe | You can add the The dashboard timeframe is the current timeframe setting for a dashboard. Users can change the dashboard timeframe to see data for a different time span, for example, instead of showing data from "the last 12 hours" it can be changed to show data from "the last 7 days". Tiles can be configured to:
