GitHub plugin
Monitor the Incidents, Issues and Pull Requests from your GitHub environment.
This data source indexes an organization and repositories for a given organization name. You can also retrieve private repositories if you add a personal access token (optional).
How to add a GitHub data source
Add a data source to SquaredUp
Enter your organization name.
Optionally, provide a personal access token to retrieve private repositories.
Data source access levels
Access Level:
Click Add.
