Salesforce plugin
Index accounts and their owners from Salesforce and get access to data via SOQL (Salesforce Object Query Language) queries.
How to add a Salesforce data source
Display Name:
Connected App Consumer Key:
The Consumer Key of the Connected App you're using. You can find it in Salesforce, in the App Manager area of the Connected App. If you need help creating a Connected App, please refer to the Salesforce documentation: Salesforce: Create a Connected App
When creating a new Connected App in Salesforce, it can take 20-30 minutes before the Consumer Key becomes active for API usage. This may cause the provider to fail to authorize. If this happens, wait 10 minutes and then try again.
Connected App Consumer Secret:
The Consumer Secret of your Connected App. You can find it in Salesforce, in the App Manager area of the Connected App.
Login Account Username:
Enter the username for your Salesforce account. The user must have access to the data in Salesforce that you want to use in SquaredUp.
Accounts with multi-factor authentication enabled are not supported.
Login Account Password:
Enter the password for your Salesforce account.
Additional Account Fields:
Specify any custom additional account fields that you wish to include in account objects. Additional account fields must be provided in a comma-separated list. You can add any fields here that you use in Salesforce, for example:
Domain_c.Additional User Fields:
Specify any custom additional user fields that you wish to include in user objects. Additional user fields must be provided in a comma-separated list. You can add any fields here that you use in Salesforce, for example:
CompanyName.Optionally, select whether you would like to restrict access to this data source instance. By default, restricted access is set to off.
Using the Salesforce data streams
Create a data stream using the configurable data stream, see Custom SOQL Query
Using configurable data streams with the Salesforce data source
Custom SOQL Query
The Salesforce data source allows you to set up configurable data streams for any kind of SOQL query. If you need help using SOQL, please refer to the Salesforce documentation: Salesforce: Salesforce Object Query Language (SOQL).
In the tile editor, filter by the Salesforce data source, select Custom SOQL Query from the data stream list and then click Next.
Select the objects that you want to query.
Query:
Enter a SOQL query.
Click Save.
A mustache parameter is a dynamic value, the actual value will be inserted to replace the field in curly braces. For example, {{timeframe.start}} will insert the start time based on the timeframe configured within the tile, or {{name}} will insert the name of the object(s) in scope.
You can use properties of objects and write them in between curly braces e.g {{name}} to use them as mustache parameters. Whenever you use mustache parameters, you need to use a scope of objects that contain the property you're referencing.
For example, if objects of type "host" have a property called name, you can use {{name}}. This will resolve {{name}} to the value of the name property of the different "host" objects used in the scope.
