ServiceNow plugin
Monitor the Incidents and Change Requests from your ServiceNow environment.
How to add a ServiceNow data source
Prerequisites for the ServiceNow account
How the ServiceNow account affects the tile
The permissions of the ServiceNow account you are using for your ServiceNow
We recommend using a service account, which means you create an account specifically to use with the ServiceNow
ServiceNow permissions assignment with roles
Give the ServiceNow account the ITIL and rest_api_explorer roles.
ServiceNow permissions assignment with ACLs, in place of roles
If you don't want to use the ITIL role (for licensing or security reasons) give the ServiceNow account only the rest_api_explorer role and use ACLs to give the account more rights.
Using accounts without the ITIL role may cause data streams to error.
How to add the necessary ACLs to your ServiceNow accountWhen you are using an account without the roles specified in this article, then the functionality of the ServiceNow
plugin is limited. You can grant the specific permissions required more granularly by creating a custom role and assigning the specific ACLs or assigning the ACLs themselves directly to a user account:
plugin .Adding them to a role. We recommend that you create a new role specifically just for adding the ACLs to it. Then you need to assign the role to the service account you are using for the ServiceNow
plugin .A benefit of adding the ACLs to a role is that it makes them easier to manage and you can assign the role to different users (in this case, service accounts) if you want to use different service accounts for different
instances of the ServiceNowplugin .
sys_filter
sys_dictionary.*
sys_dictionary
sys_db_object
sys_ui_list
sys_db_object.*
sys_ui_list.*
Add a ServiceNow data source to SquaredUp
Enter the URL of your ServiceNow instance.
Enter the username and password for the API. See Prerequisites for the ServiceNow account
Adding Custom Classes is optional, and can be left empty. If you would like SquaredUp to import your custom classes you can list any number of classes here using their table names. By default, the data source imports the Business Application class (table name: cmdb_ci_business_app) and the Service class (table name: cmdb_ci_service).
