Datadog plugin
Monitor your Datadog environment.
How to add a Datadog data source
Display Name:
Site:
Select the Datadog site that you use to log into your Datadog instance.
API Key:
Open a new tab and log into your Datadog instance. Create an API key and copy it. Return to the SquaredUp tab and paste the API key into this field.
Application Key:
Open the tab with your Datadog instance again, create an Application key, and copy it. Return to the SquaredUp tab and paste the Application key into this field.
Using the Datadog data streams
Data streams are installed with the data source.
Create a data stream using the configurable data stream form (simplest option) Creating a data stream using the configurable data stream
Metrics
This data stream calls the /api/v1/query endpoint with a pre-set query, and allows you to enter a custom metric name.
In the tile editor, filter by the Datadog data source, select Metrics from the data stream list and then click Next.
Select the objects that you want to use and then click Next.
Type a Metric, for example:
system.cpu.userSee Datadog: Metrics
Click Save.
