Dynatrace plugin
Monitor the Applications and Synthetic Transactions from your Dynatrace environment.
Note: If you're not using a cloud-based Dynatrace environment and instead are running Dynatrace in your internal network, you want to use the on-premises Dynatrace data source, see How to add a Dynatrace on-premises data source.
Prerequisites
Generate a new token in Dynatrace and save the token to use when adding the data source to SquaredUp later, see Dynatrace: Generate an access token
How to add a Dynatrace data source
Display Name:
Base URL:
Enter the Base URL to your Dynatrace environment, for example
https://myEnvironmentID.live.dynatrace.com/API Key:
Enter the API key you created in your Dynatrace environment.
Configure and deploy an agent
Add a Dynatrace data source in SquaredUp
Display Name:
Agent Group:
Base URL:
Enter the Base URL to your Dynatrace environment in the following format:
https://your-domain/e/your-environment-id/API Key:
Install Sample Dashboards:
Using the Dynatrace data streams
Data streams are installed with the data source, see Tips for using the Dynatrace data streams
Create a data stream using the configurable data stream form (simplest option) see Creating a data stream using the configurable data stream
Metric
This data stream calls the /api/v2/metrics/query endpoint with a pre-set query, and allows you to enter a custom metric key.
In the tile editor, filter by the Dynatrace data source, select the configurable Metric data stream that you want to use and then click Next.
Select the objects that you want to use and then click Next.
Select a Metric Key from the dropdown, for example:
builtin:service.response.timeOptionally, tick Show only most recent value if you want to only show the one latest value. If this is not ticked then any historical data is shown, so line graphs over time are possible. If you are showing historical data, you might like to name your data stream to indicate this, for example
Availability History.Click Save.
This data source comes with several data streams that you can use in the tiles on your dashboards. Here you'll find tips and ideas for using these data streams to display the data you're interested in.
Using the Health data streams
You can visualize the status of your hosts or services with the Dynatrace Health data streams. Available Health data streams are:
Application Health
Browser Monitor Health
Database Health
HTTP Monitor Health
Host Health
Service Health
You can visualize the data as blocks. You will need to set up the requirements for potential problems related to the state of your hosts and services from your Dynatrace account. SquaredUp will then visualize the block as red/green based on the reported problems from Dynatrace. If the block displays as green, there are no problems with the state of your hosts or services. If the block displays as red, there are problems associated with the state of your hosts or services. Alternatively, you can visualize the data as a table in SquaredUp.
