Metrist plugin
Visualize the state of your Metrist monitors.
How to add a Metrist data source
Display Name:
API Key:
Enter an API key for your Metrist account.
Data source access levels
Access Level:
Testing outcomes
Using the Metrist data streams
Health
The Health data stream allows you to visualize the state of your Metrist monitors. In the tile editor, filter by the Metrist data source, select the Health data stream and then click Next. Select an object, or select Dynamic selection, and then configure the settings as you wish.
You can visualize the data as blocks. SquaredUp will then visualize the block as red/green based on the reported problems from Metrist. If the block displays as green, there are no problems with the state of your monitors. If the block displays as red, there are problems associated with the state of your monitors. Alternatively, you can visualize the data as a table in SquaredUp.
