Pendo plugin
Visualize your Pendo report data and custom aggregation queries.
How to add a Pendo data source
Create an Integration Key in Pendo
Create an Integration Key in Pendo, see Pendo: Authentication
Copy and note the Integration Key somewhere safe.
Add the Pendo data source to SquaredUp
Display Name:
Integration Key: Enter the key you created in Pendo.
Using the Pendo data streams
Data streams installed with the data source see Using the Pendo Reports data stream
Create a data stream using the configurable data stream see Creating a data stream using the configurable data streams
This data stream calls the /report/{reportId}/results.json endpoint.
Scope to a Pendo Report
Select Pendo Report from the data stream list
Number of Visitors
This data stream calls the /aggregation endpoint.
Scope to a Pendo Organization
Select + Number of Visitors
Enter a Pendo Segment Id
Custom Aggregation Query
This data stream calls the /aggregation endpoint and allows you to enter a custom Pendo aggregation query.
Select + Custom Aggregation Query
Enter Aggregation Query, for example:
"requestId": "account-list",
"pipeline": [
"source": {
"accounts": null
