SCOM plugin
Monitor your SCOM environment, including Windows Computers, Enterprise Applications and more.
The SCOM data source is for accessing data in your on-premises SCOM environment, see How to add a SCOM data source
The SCOM Managed Instance data source is for accessing data in the PaaS monitoring service. See How to add a SCOM Managed Instance (MI) data source
Configure and deploy an agent
Configure the agent for a SCOM data source
Why do agents for the SCOM data source need special configuration?
The SquaredUp agent service uses the local system identity by default. SCOM uses Windows authentication which requires at a minimum Network Service or a Domain User account, the agent you use for the SCOM data source needs to have its service identity changed to such an account.
Permissions for the service account:
Consider which objects you want to index and set the permissions for the service account accordingly. As the SCOM data source supports SCOM RBAC you can use scoping in the user role for the account in SCOM to control which objects will be indexed.
You need to manually add the service account to the opsmgreader role of the Data Warehouse in the SCOM console see Manually creating the Data Warehouse permissions
Add a SCOM data source in SquaredUp
Display Name:
SCOM Management Server:
Enter your SCOM management server as a FQDN, for example
server.domain.localSquaredUp DS for SCOM URL:
Optional. If you use SquaredUp DS for SCOM, you can enter the URL to your instance. This will create a link from a SCOM object in SquaredUp to the same object in your SquaredUp DS for SCOM.
Enter the URL to the root domain including https, for example:
https://myserver.mydomain/SquaredUpv5/Agent Group:
Click Add.
The SCOM Managed Instance data source is for accessing data in the SCOM MI PaaS monitoring service. Use the instructions in this section to configure SCOM MI and add the SCOM MI data source to SquaredUp.
If you only have the traditional on-premises SCOM (and have followed the instructions to add the SCOM data source above) and do not have SCOM MI then you do not need to use this section to add the SCOM MI data source.
Configure SCOM Managed Instance in Azure
Log in to the Azure Portal.
Search for
SCOM Managed Instanceand click on the instance to connect to SquaredUp.Under Reports click the PowerBI tab.
Copy DB Name and DB Host URL. You will use these in the next section adding the data source to SquaredUp.
Click the SquaredUp link at the bottom of the page to login to your SquaredUp organization, and follow the steps in the next section to add the data source.
Add a SCOM Managed Instance data source in SquaredUp
Display Name:
DB Name:
The database name of the SCOM MI data warehouse. This value can be found in the Reports section of the SCOM MI instance.
DB Host URL:
The URL of the SCOM MI database server. This value can be found in the Reports section of the SCOM MI instance. Keep the comma and port after the URL.
Username:
Enter the username of a SQL account to logon to SCOM MI.
The username must have data warehouse reader permissions to access SCOM MI data.
Password:
Enter the password of the SQL account.
Click Add.
Using the SCOM data streams
Create a data stream using the configurable data stream see Creating a data stream using a configurable data stream
Metric
This data stream calls an API endpoint to get metrics from your SCOM instance, and allows you to enter a custom object name, counter name and instance name.
In the tile editor, filter by the SCOM data source, select Metric from the data stream list and then click Next.
Select the objects that you want to use and then click Next.
Enter an Object Name, for example:
LogicalDisk.Enter a Counter Name, for example: Free Megabytes.
Optionally, enter an Instance Name.
Optionally, enter the Top N number of items you want to see.
Check Sort descending if you want to sort the results descending instead of ascending.
Click Save.
