Cloudflare plugin
Monitor the state and performance of your Cloudflare websites.
How to add a Cloudflare data source
Display Name:
API Token:
Go to your Cloudflare account, create an API token using the template Read all resources, and paste it in here. If you need help creating an API token, please refer to the Cloudflare documentation: Cloudflare: Creating API tokens
Install Sample Dashboards:
