Nagios XI plugin
Monitor key metrics from your Nagios environment.
This plugin adds a data source that streams data from your Nagios XI environment into SquaredUp. In your Nagios environment, metrics about your hosts are called "services", which is why the data source creates objects of type host and service. The data source comes with Data Streams to show you CPU usage and Memory usage of your hosts.
You can also visualize the status of your hosts or services with the Nagios XI Health Data Stream.
How to add a Nagios XI data source
Display Name:
Agent Group:
Base URL:
Enter the full URL to your Nagios XI instance, for example
https://your-host/nagiosxiAPI Key:
Enter the API key you created in your Nagios instance.
Note: Nagios API keys are user-specific. Make sure you created the API key with a user account that has access to all the data you want to see.
Click Add.
