Cisco DNA plugin
Monitor your Cisco DNA Center devices. This plugin allows you to add a data source with a small selection of data streams so you can to view the status of devices on your network.
How to add a Cisco DNA data source
Configure and deploy an agent
Add a Cisco DNA data source in SquaredUp
Display Name:
Agent Group:
Cisco DNA URL:
Enter the URL of your Cisco DNA server.
Account Username:
Enter the username for your Cisco DNA account.
The account must have API access.
Password:
Enter the password for the API user.
Using the Cisco DNA data streams
There are four data streams installed with the data source:
All Devices
Shows data for all wireless controllers, all unified APs and all unreachable devices.
Unreachable Devices
Devices with an error next to Reachability Status will be shown.
All Wireless Controllers
Shows data for all wireless controllers.
All Unified APs
Shows data for all access points.
Write a custom data stream (advanced use) see Writing a custom data stream (advanced users)
You can create new data streams that will filter on specific properties by adding that property to the datasourceconfig. You are able to do this by setting the value to the search value from the following list: hostname, managementIpAddress, family, reachabilityStatus, managementState, location, softwareVersion, id.
For example:
"dataSourceConfig": {
"endpointUrl": "/dna/intent/api/v1/network-device",
"hostname": "testing.global.example.com"
