How to use the Web API tile with PagerDuty
This article covers how to use the Web API tile to display live API data from PagerDuty on a dashboard or perspective.
Dashboard Server uses the PagerDuty account that you configure, and queries will be updated as the page updates, by default every minute.
If you need more information about using the Web API tile in general see
This article covers several areas:
Walkthrough: Adding a Web API tile to a dashboard to show PagerDuty alerts
Walkthrough: Adding a Web API Scalar tile to a dashboard to show PagerDuty incident counts
Prerequisites
- The SquaredUp server must have access to your PagerDuty instance, since it is the server that connects to PagerDuty, and not your users' browser.
- If you use a proxy server you may need to configure the proxy to allow the SquaredUp server to communicate with PagerDuty (How to configure Dashboard Server to use a proxy).
- A PagerDuty account. You may need some help from a PagerDuty admin to get an account with the correct privileges.
Adding a PagerDuty provider in Dashboard Server
Before you configure the Web AP tile for use with PagerDuty you need to create a PagerDuty provider in Dashboard Server.
For PagerDuty the provider must be created as a simple provider:
First box (name):
It is important to use http GET mode and to set the key path in the response data section to alerts. This is described in the steps below.
On the top navigation bar in Dashboard Server click the + to create a new dashboard, and give your dashboard a title.
Click on the Web API tile.
Select Web API (Grid).
Leave the scope section blank for this walkthrough.
In the provider section select the PagerDuty provider that you created earlier.
In the http mode section leave the http method set to GET.
Type
alertsin the box after the URL. The URL shown here is the URL you specified when you created the PagerDuty Web API provider.
Leave the headers & data section as it is for this walkthrough.
In the response data section you should see some data in the response data box. If there isn't any data check the configuration of your provider.
Type
alertsinto the key path box.
At this point you should see some data returned.
Click hide next to some of the columns you might not wish to show, e.g. id, type, summary, self, html_url, resolved_at, alert_key, suppressed, service, incident, first_trigger_log_entry, body, integration, privilege.
You may like to rename the columns to make them more readable, e.g. created_at to Created, status to Status and severity to Severity
To make the created date and time more readable you can use mustache syntax with timeago (How to use Custom Labels) in the custom template. Click edit next to Created and paste the following in to the custom template box:
{{timeago(value)}}This shows how long ago the alert occurred.
You may like to add further columns for additional data. For help customizing the columns of data see How to use the Grid Designer.You can also add columns.
Click Add, give the column a name, such as
Service, and in the custom template box click the mustache helper button
and select the value you require, for example {{value.service.summary}}then click done. Leave data key path empty.
Other columns you might like to add include:
name:
Messagewith custom template:{{value.body.cef_details.message}}name:
Websitewith custom template:{{value.body.cef_details.details.hostname}}name:
Related Incidentwith custom template:{{value.incident.summary}}You may wish to change the order the columns by dragging them into position.
The Grid Options Row Link property allows you to automatically link each row to a parameterised hyperlink. Click on the mustache helper button and then select
{{incident.html_url}}from the drop down list.
Click done.
It is important to use http GET mode and to set the key path in the response data section to incidents.
Select Web API (Scalar).
incidents
The headers & data section is where you can pass key variables through to PagerDuty. Click the add button under data to add the following data name and value settings:
Click apply changes.
In the response data section you should see some sample data shown. Type
incidentsinto the key path field.
Click next to move to the scalar section where you can change the font size if you wish.
Click done.
Repeat the above steps to create two new tiles, one for Triggered and another for Acknowledged substituting the following data name and value settings in lower case in the headers & data section:
Hints and Tips
- Look at the PagerDuty API documentation or speak to your PagerDuty expert.
- Use custom labels to improve data formatting see How to use Custom Labels
