How to use the Alerts tile
The Alerts tile allows you to view alerts on your dashboards and perspectives.
You can add alerts tiles to any dashboard or perspective.
For more information about Azure Alerts see Overview of alerts in Microsoft Azure.
How to configure an Alerts tile
Add a new tile to a dashboard and choose the Alerts tile.
Select the visualization for your Alerts tile and click next.
Note: You can choose between the List and the Donut visualization for either Resources, Groups, or Subscriptions.
ListThe Alerts list shows a list of alerts.
You can drilldown from an alert on the Alerts list, to view that alert's drilldown page in Dashboard Server. From there the view in portal
button at the top right of the page, allows you to link to the Azure portal to view the alert.
DonutThe Donut tile shows a summary of the number of alerts either by severity,
alert state or monitor condition . Clicking on a donut segment or on the key shows a list of alerts with that severity,alert state or monitor condition .
Scope:
The scope section allows you to define the objects for which alerts are shown.
If you see the message "You do not have access to all of the tenants currently selected" or "Tenant ID could not be resolved"In a multi-tenant environment a user who does not have access to all tenants will see this message if they attempt to edit a scope containing tenants that they do not have access to. This may be because:
Symptoms
A tile scope shows:
Procedure
You can add multiple
items . To remove anitem click the x to the right of its name.Tip: Start typing and after two characters you'll see suggestions that match the name appear.
Filter by type:
Filter by type:
Filter by type:
databasesand selectingSQL databases.Show hidden types This works in the same way as the Show hidden types option in the Azure portal.
resource . A dynamic scope consists of two different states:the configuration of the scope in the tile (for example, "consider child objects of type logical disk for the currently viewed object")
resource you are currently viewing ("this object has 5 child objects of type logical disk")
resources you are viewing.On perspectives, you can scope tiles to:
this resource
other resources Gives you the normal, non-dynamic scope options you are used to when scoping tiles on dashboards. This means the tile will not dynamically adapt it's content to the currently viewed
resource , it will always show data for the staticresource picked here.Since the power of perspectives is that their tiles can show data for different
resources depending on whatresource is currently being viewed, you should only select this option when you are sure that there is no relationship between the desired scope and the currently viewedresource .
this resource
resources depending on whatresource is currently being viewed, you should only select this option when you are sure that there is no relationship between the desired scope and the currently viewedresource .Timeframe:
The timeframe section allows you to determine the timeframe for the data. You can choose either to use page timeframe, which allows users viewing the page to change the timeframe on the fly, or for you to set a fixed specific timeframe which will ignore the page timeframe settings.
The Alerts tile timeframe shows a maximum time period of last 30 days. This is because Azure only stores 30 days worth of Alerts data.
Filters:
The filter section allows you to control which alerts are shown by the tile.
Settings for different visualizations:
Settings for ListsSort
Sort allows you to change how the list is sorted. You can sort ascending or descending by:
last modified
monitor condition
name
raised
severity
Limit
Allows you to define a maximum of alerts that will be shown by the list tile.
Columns
The columns section allows you to show the column titles, rename titles, sort and hide columns in the Alert list.
Note: If you want to be able to resize the width of columns, you need to show the column titles (by activating the check box show column titles). This enables you to control the default width of the columns by dragging them to the size you want. It also enables your users to temporarily change the column width by dragging the columns to the size they want while they are looking at the dashboard.
Note: When resizing the width of columns, make sure to leave enough space in the last column for the update state functionality to be shown:
Note: Even if you show column titles, the severity column won't show a title because it only contain the severity icons.
Display
Use the slider to adjust the font size.
Settings for DonutsGrouping
When configuring the Alerts Donut tile the grouping section allows you to select whether the donut shows by severity,
alert state or monitor condition .Display
Size mode:
Click done to save the tile.
The tile now shows alerts according to your settings.
Known Issues
Blank drilldown page after clicking on an alert in Dashboard Server
If you have upgraded from v4.4 to v4.5 you will not have the pre-populated Alert drilldown perspectives. You can populate the drilldown page by creating two new perspectives as described below.
Drilldown by clicking on an alert in an Alert list.
Click the small gray plus button to add a new perspective.
Click on the Edit JSON button
Copy the JSON below and paste it into the JSON box, overwriting everything already there.
Copy{
"content": {
"_type": "layout/list",
"contents": [
"_type": "layout/column",
"columns": [
"contents": [
"contents": [
"_type": "tile/azure-structure",
"config": {},
"description": "",
"title": "Structure"
"width": 47.914
"contents": [
"contents": [
"_type": "tile/azure-monitoralert-properties",
"config": {},
"description": "",
"title": "Monitor"
"width": 52.085
"_type": "tile/text",
"config": {
"display": {
"contentTemplate": "<pre class='u-text-normal'>{{properties.essentials.description}}</pre>"
"description": "",
"title": "Description"
"_type": "tile/azure-monitoralert-history",
"config": {
"display": {
"autohide": true,
"columnOverrides": {},
"columns": [
"comments",
"description",
"modificationEvent",
"oldValue",
"newValue",
"modifiedAt",
"modifiedBy"
"customColumns": {},
"rowLink": "",
"showHeaders": true
"description": "",
"title": "History"
"_type": "tile/azure-monitoralert-smart-group",
"config": {
"display": {
"columns": [
"severity",
"name",
"targetResourceGroup",
"targetResourceName",
"targetResourceType",
"startDateTime",
"alertState"
"source": {
"alertStates": [],
"limit": 250,
"monitorConditions": [],
"monitorServices": [],
"severities": [],
"timeframe": {
"range": "last30days",
"type": "fixed"
"description": "",
"title": "Smart Group"
"id": "43e1362a-8cef-4bce-8ac9-f7de0f46242c",
"match": {
"type": "azure/alert"
"name": "Alert",
"rank": -1000,
"derivedFrom": "00000000-0000-0000-0000-000000000000",
"createdFromReference": {
"packId": "ddb53c1e-ffe4-40ad-bdc2-22b0bcad5e30",
"itemId": "b09678cb-6312-402b-8acd-f956d30ea2ac",
"packversion": "1.0"
}Click the apply changes button below the Perspective JSON box.
Publish the perspective.
Click the small gray plus button to add another new perspective.
Copy{
"content": {
"contents": [
"columns": [
"contents": [
"contents": [
"_type": "tile/object-properties",
"config": {
"display": {
"path": "properties.context"
"description": "",
"title": ""
"width": 100
"id": "3248ba18-bc23-4d91-99b0-3574eaf1ce20",
"match": {
"name": "Context",
"rank": -2000,
"itemId": "74bf5348-261d-41e8-8cb3-08e97bdba809",
}Go back to your Alerts list tile, and click on another alert to check that the Alert and Context perspectives are shown.
