How to add a Web API provider
What are Integrations?
What is a provider?
About Web API providers
The Web API integration allows you to create Web API providers. A Web API provider is a generic provider that contains the connection details to any REST API that returns JSON.
Which Integrations can I use for Web API tiles?
You can use generic and dedicated integrations to create your own providers. Of course, a dedicated provider like ServiceNow will only work with the ServiceNow API.
You need to have at least one provider before you can use Web API tiles (see How to use the Web API tile).
Generic Web API providers
| Simple | No authentication, basic authentication (username and password in a header) or Windows authentication (configured automatically to use the application pool identity account). |
| Basic auth | Basic authentication. Your specified username and password will be Base64 encoded automatically. |
| OAuth | Token-based authentication according to the OAuth 2.0 standard. Many APIs use OAuth 2.0 for authorization, and will require an OAuth provider to include the additional information about how to authorize against the service. |
Walkthroughs for creating generic Web API providers for popular APIs
First box (name):
1. Add a new provider in Dashboard Server Azure Edition
Click on the authentication type OAuth
In the service name box type in a suitable name for this provider. This name is used to create a URL so it is best to avoid spaces and non-alphanumeric characters., e.g. GoogleAnalytics.
Leave the grant type as authorization code
https://www.googleapis.com/The authorization URL should
https://accounts.google.com/o/oauth2/v2/auth?access_type=offline&include_granted_scopes=trueThe parameters appended to the authorization URL allow Dashboard Server to continue to access the API after the first hour. Without them Dashboard Server can't reauthorize the provider automatically after the first token has expired. access_type=offline - requests that the API return a refresh token to keep the connection alive. The token expires every hour and without a refresh token, you have to manually reauthorize the provider each time. include_granted_scopes=true - allows the refreshed token to have the same permissions as the original request when the user was present.
The token URL should be
https://oauth2.googleapis.com/tokenAt this point we need to save the provider and follow the next steps to obtain a client ID and secret from the Google Developer Console, after which we will return to complete these provider details.
Click save to save the provider.
Copy the redirect url displayed. This will be used in the next section.
2. Configure the Google Developer Console
- Visit the Google Developer Console
- Create a new project as required.
- Select Create Credentials > OAuth Client ID
- Select Web Application
Enter the following:
Name: This can be anything
Authorized JavaScript origins: Should be the hostname of your SquaredUp server including the http/https
Authorized Redirect URIs: Should be the redirect url copied from Dashboard Server right-hand menu ☰ > system > web api. It will be your Dashboard Server instance followed by
/ext-core-webapi/callback/GoogleAPIProviderwhereGoogleAPIProvideris the name of the provider you created.For example:
https://SquaredUpServer/SquaredUpv5/ext-core-webapi/callback/GoogleAnalyticsWhere
SquaredUpServeris the name of the server where Dashboard Server is installed.- Click save/create
- Copy the client ID and secret to use in the next section.
3. Complete the provider setup in Dashboard Server
- Click on the provider you created earlier to edit it.
- Paste in the client id and secret copied from the Google Developer Console.
- Paste in the relevant authorization scope from OAuth 2.0 Scopes for Google APIs. For example, for Google Analytics it should be the URL scope listed for 'View your Google Analytics data' which is
https://www.googleapis.com/auth/analytics.readonly - Click save. You will be redirected to Google to login and authorize and then back to Dashboard Server.
If the configuration is correct then you will see a green tick.
If the provider is not authorized it could be that some of the provider configuration is incorrect (for example the username, password, secret etc), or if you use a proxy it could be that the proxy is not configured. See How to configure Dashboard Server to use a proxy
You can now add Web API tiles using this Google API provider, see How to use the Web API tile with Google APIs, such as Google Analytics
Add the following:
value:Bearer<API token from Pingdom>You can create an API key (token) by logging in to Pingdom > Settings > Pingdom API > Add API token
Bearerand a space
Click Save.
Dedicated providers
| ServiceNow | |
| Elasticsearch | |
| Splunk |
Adding a Web API provider
You are now ready to use this provider in a Web API tile (see How to use the Web Content tile).
Further help for adding Web API providers
Blog: Integrating Dashboard Server with external APIs: UptimeRobot
Webinar that includes New Relic
For other APIs, take a look at our Community Answers site, where there's a wealth of knowledge about APIs.
