How to add an SQL provider
What are Integrations?
What is a provider?
About SQL providers
Since Dashboard Server version 5.4 you need an SQL provider to use the SQL tile. .
Adding an SQL provider
Make sure you have access to the database you want to use.
Configuring access to a database for an SQL providerTo be able to query databases, such as the Operations Manager database, the Dashboard Server application pool identity needs to be given the db_datareader role in SQL Server Management Studio for the database you wish to query. See How to configure access to a database for use with the SQL tile
Provider name:
Driver and Connection String:
Connection strings when you are using Microsoft SQL Server DriverConnection string for any database:
With integrated security:
CopyServer=<SQLservername>;Database=<DatabaseName>;Integrated Security=True;With username and password:
CopyServer=<SQLservername>;Database=<DatabaseName>;User Id=<username>;Password=<password>;If the SquaredUp server and SQL server are in the same domain you can just use the SQL server name, if they are not in the same domain you should use the fully qualified domain name.
CopyServer=<SQLservername>\\<InstanceName>;Database=<DatabaseName>;Integrated Security=True;Example:
CopyServer=SQLServer1\\Main;Database=CRMDB;Integrated Security=True;If you want to specify a port
CopyServer=<SQLservername>,<PortNumber>;Database=<DatabaseName>;Integrated Security=True;Example:
CopyServer=SQLServer1,51433;Database=CRMDB;Integrated Security=True;
Connection strings when you are using ODBCNote: You need to use 64-bit ODBC drivers.
Example:
CopyDriver=<ODBCdriverName>;Server=<SQLservername>;Database=<DatabaseName>;User Id=<username>;Password=<password>;If you are using a System DSN
CopyDSN=<DSNname>Click save to save your new provider.
